| agentmulder
   | | Splines, brakes, swivel inspect/overhaul - what's involved? |  |
 Ok so a wee bit of slop/backlash at the rear (when moving it with the wheels up it sounds like the reflected 'clunk' I hear when driving near a wall).
 Got a full set of Ferodo brake pads to install as well and then there is the swivel grease situation to check at the front.
 Does anyone have a good list of do's and don'ts here and how best to disassemble/check/clean/lubricate/bleed/fix/replace/re-assemble/torque all of this? Or is it all along the lines of 'if you find a circlip, take it off', 'if you find a bolt, unscrew it' and everything makes sense in both directions?
 Special tools?
 Easy, but non-obvious ways to get around certain tasks?
 Tightening torques for all the bolts??
 I'm particularly interested in not stuffing up the brakes/brake hydraulics...
 Wisdom appreciated
  Solved the bowel problem, working on the consonants... |
                |  12th May 2016 1:39am |  |
