![]() | Home > Td5 > fault code 10.1 air conditioning fan drive open load (logged |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
A/C Fan is electric fan behind the mask. It is powered from a relay and the relay is controlled by TD5 engine ECU. Your fault means the open circuit between TD5 ECU and coil od the relay. Check relay and connectors for damage/corrosion. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
| Castillo Member Since: 23 Nov 2012 Location: Tavastkyro Posts: 41
Thanks. How many aircon's relays are td5 defender. There is some relays under passenger seat and the yellow one says "naps" when white switch turn "one". Blue switch do anythig under passenger seat's relay, nothing "naps" if I turn on blue switch. I opened this yellow relay "box" and inside was "som new" defender 110 td5 2006
Look for RAVE - technical documentation from LR - there are schematics and placement and pictures of all connectors. And lot of other usefull technical information. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
There are some yellow relays (Ford V23136-B1-X33) under passenger seat. Where I can buy this kind of relays. Land Rover yellow relays in many webshops are differend numbers (YWB10027, YWB10012, YWB000150). Are those allright. How I can buy correct yellow relays to my car
No need for YELLOW relay - it is standard car relay, nothing special. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Now I have replaced new air con relays and fuses, but nothing help. What I will do after this. defender 110 td5 2006
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge information for your Air con diagnostic good luck |
Thank you very much
| All times are GMT |
