Home > Td5 > Td5 Cylinder Head Repair ?
Page 2 of 2 <12
excossack
Mine wasn't dropping diesel into the oil, just losing water. Still got the old head in the shed. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #212192 18th Feb 2013 6:24pm
UNIT 2B ENGINEERING
Yes it is possible to see the crack with the naked eye or magnifying glass,look across from the exhaust (turbo) side into the injector housings , you will see a crack at around 1 oclock a very fine hairline crack right at the top extending straight down around 25mm they always crack in the same place look carefully at 1,2,3 and 4 cylinders.you can some times feel it internally with your finger nail.
Post #212270 18th Feb 2013 9:46pm
Lewisgregory8
2014 Defender 90 Puma 2.2 HT Fuji White
I have td5 10p head for sale which has been pressure tested and its fine
Let me know if your interested
Post #215168 1st Mar 2013 3:39am
How much?
Post #215175 1st Mar 2013 7:09am
Lewisgregory8
£450
Post #215252 1st Mar 2013 1:23pm
Steve Sidebottom
England 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
The head on my TD5 cracked on number 1 cylinder and caused diesel to get into the engine oil. Oil level rose and engine over ran on motorway causing massive engine damage. 2 new cylinders required, bottom end of engine rebuilt and repair to the cylinder head. The head was welded by Unit 2B engineering and refitted. This happened at 100k miles, vehicle was run without any problems until 125k when I sold it. Cost of repairing the head compared to a new head meant this was a chance worth taking. A close eye was kept on engine oil levels for the first 5k miles.
Post #530129 9th May 2016 2:30pm
adseybear
Canada
What are the contact details for Unit 2B Engineering, google isnt being much help?
I would quite like my old head pressure tested and welded if possible so I can sell it if it is indeed cracked.
Post #530357 10th May 2016 11:13am
NickMc
Ian 07733 621456 between 8 am and 8 pm
You'll find him on ebay if you look along the lines of td5 head welding.
Ive had a few done for customers at their request on a budget and 4 years down the line its still fine.
Post #530424 10th May 2016 7:09pm
miker
Hmm. I have my old engine in the garage. Turner 15P block & AMC head. No cracks or anything, timing chain snapped though so valve damage etc. I had plans to strip it down anyway, based on this it would be worth selling?
Post #530443 10th May 2016 8:27pm
Fatboy Slim
Wales
How much do you want for it ?
Post #530466 10th May 2016 9:06pm
miker
Depends if there's any damage on it. I was having vague ideas about keeping it on the shelf just in case. I'll have a think and let you know?
Post #530479 10th May 2016 9:24pm
Soupy
I've had 2 heads repaired (by the fellah on ebay) on our works td5s, one of them was about 2 years (30k miles) ago.
No problems. I wouldn't hesitate recommending the service.
Post #530613 11th May 2016 11:19am
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Cracked cylinder heads
How common is this issue of the cracked cylinder heads?
Post #707352 15th May 2018 5:31pm
Soupy
I think going porous is more common than cracking.
Post #707475 16th May 2018 8:42am
Page 2 of 2 <12
