Home > Maintenance & Modifications > Rear Camera Install
Page 2 of 4 <1234>
Stacey007
^ Thanks
Will give it a go hopefully enough flex for the wire.
Post #530277 9th May 2016 9:41pm
Stiff1
On my camera there are two red wires and one black to go to the reverse light. Instructions seem to suggest connecting the two red together and then joining the live at the reverse light. Presume the black goes to the negative???
In your pics it looks like you have a red from the camera going to both the positive and negative?
Have my yellow jack connected to the head unit but not sure where the bare red needs to go, presume one of the holes on the block connector?
Some direction would be much appreciated.
Post #530832 11th May 2016 11:26pm
Two red would suggest to me, one permanent live, the other turn on live from reverse feed.
If they were both permanent live cam would be on all the time.
Some people like to have a Cam live with HU on only so they can use it as a rear cam as well as a reverse cam if that makes sense.
Black is common earth...
Do the two red wires have any tracer colours at all?
Post #530834 11th May 2016 11:34pm
Roy5695
when i wired my camera in, there was a permanent live which kept the camera active and a switched live (from reverse light/a switch/ whatever you desire to switch it) which activated the screen. if you attach them both to the switched live it might take longer for the screen to come on, this is what I found any way.
Post #530850 12th May 2016 4:58am
Stiff1
So this is what I have at the back.
Post #530901 12th May 2016 9:18am
Stacey007
Sorry I've no idea really with the wires, I'm doing it according to the badly written Chinese to English translated instructions.
I'm hoping mine will turn on when its plugged in, but really not sure Smile
Anyway screen arrived today, looks quite nice, maybe a little shiny as the 4.3" version was Matt, but I wanted the 5" for better screen resolution. (may have to gloss the interior trim soon...)
Folded down mode
Folded up mode by pressing the button
Then the wires,
As this has the ability to have two camera inputs I'm OK with the Yellow and white lead as the Yellow on this screen will connect to the yellow from the camera.
The red Power cable (in the picture) which then connects to the back splitting to Red and black I guess needs to go to 12V in the car somewhere that only switches on with ignition and off when key out (such as Cigarette lighter)
I'm still confused where this wire goes from the camera at the other end?
What's the easiest way to tap in to a 12v that come on with ignition and off with key? If its the cigarette lighter how do I get to it.
Post #530959 12th May 2016 12:05pm
You could use HU ignition power, as a cam only draws milliamps.
Myself personally I'd use the lighter feed and fit a lower in-line fuse.
Post #530968 12th May 2016 12:35pm
Ayrshirelandy
This is great as it is coming up next and I opted for the Americam but it is a number plate plinth fit. Great post Thumbs Up 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more...........
Post #530991 12th May 2016 2:01pm
VeeTee
Netherlands
Then the wires,
Usually the RCA connectors are color coded like: Yellow: Composite video, Red & White: Audio. So you only use the Yelllow one for the rear camera for now. If you also want to use the screen for video playback with other equipment (e.g. Video iPod) then use the Red & White also.
I guess the red wire coming with the yellow connector from the rear camera is for activating the screen and/or camera if rear gear is selected (when connected to the rear light or gearbox connector). Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #530999 12th May 2016 2:58pm
Stacey007
VeeTee
Thanks happy with the Yellow from Camera going to the yellow to the screen
With the Red wire from the camera (with the yellow) do I need to connect this? it didn't say anything in the book.
As at the camera end at the rear there is also a red wire unconnected (which came off the yellow)
My plan will be to connect the screen with power from say the cigarette lighter and then just plug the yellow camera lead in?
I've got the camera powered buy the reversing light so should come on when I engage reverse?
Thanks in advance
Post #531005 12th May 2016 3:24pm
VeeTee
Netherlands
Stacey,
As I found in de Q & A Section this other red wire (emerging from the yellow connector) is to use for another 12V source, as with some cars (I guess modern can bus systems) the power from the rear light bulb is not powerful enough to power the camera. So I guess in your case just ignore it - or you could connect it to a switched 12V (with a switch on the dashboard), so you can manually switch the camera on even if you are not in reverse (I have wired mine this way, and I find it useful with towing another car, I can have a view on slowly tensioning the towing cable - but then my camera is in the middle position above the door). Cheers, Vincent
MySite
Post #531031 12th May 2016 4:57pm
Stacey007
Thanks.
Will try and have a look this weekend.
Post #531114 12th May 2016 8:57pm
Stacey007
OK so nice day and left early to Have a go.
Stopped at a motor factors on way as googled I may need to remove the radio so to make it easier £2.50 for the pulley things.
So Started, removed radio
The hardest part was working out how to hide the cables from the camera coming up from the back and the screen power. I decided to make a tiny hole just above my glove box feed the cable through this through the glove box and then find it through the hole the now removed radio was.
Its only a thin wire so once cable pushed through and glove box shut this is what you see
Post #531356 13th May 2016 8:27pm
Stacey007
The cable from the camera at the rear comes down the passenger headlining and then hidden behind the dashboard at the side (bulk head?) 2 screws taken out to make easier.
Post #531357 13th May 2016 8:29pm
VeeTee
Netherlands
Oh oh, do I see some brown coloured something on your bulkhead? Shocked Confused Cheers, Vincent
MySite
Post #531360 13th May 2016 8:39pm
Page 2 of 4 <1234>
