Home > Puma (Tdci) > 2015 110 Damp Footwell - rapair update
Moles
Thought folks might be interested in my damp Defender.
Not had this vehicle too long, and the only issue during my purchase checkout was a damp footwell.
After spending a ibt more time with it, it's obvious some surface rust on the footwell, so into the local dealer this week. Leak identified as windscreen to bulkhead, and has been fixed, but the rust has proved a bit more extensive. They have striped down to the bulkhead, as apparently they have seen this leak before causing bulkhead rot.
So far can't fault their efforts in trying to put it right, but proof will be whether LR cover the full cost of the treatment/respray.
Anyone else have similar experience?
BTW, dealer tells me they have seen a few like this, hence going the extra to get it fully treated.
Moles.
Post #529845 7th May 2016 10:42pm
mk1collector
Quite a common fault, my mrs's double cab had the same leak fixed under warranty. I've read the rust comes from and uncoated/unpainted piece of metal or bracing behind the dash. Lr should pay for the full fix. Ray
My build thread
Post #529859 7th May 2016 11:10pm
Pickles
When you say "Windscreen to Bulkhead", do you mean the foam seal area?...or where the w'screen rubber seal seals against the bodywork,.....a pic maybe?
Pickles.
Post #529876 8th May 2016 2:24am
Moles
Sorry, I'm just quoting what the dealer found, not seen it myself, but I'll try to get a more detailed explanation when I go see them.
Moles.
Post #529903 8th May 2016 9:46am
barbel jim
Yep the foam seal is a very common failure. Dealer did mine........ Not that, reckons it was missing bolts in the footwell and.....................
This happened last week Rolling Eyes
so its not that either Rolling with laughter They've only had it for 16 days. looks like they'll have it some more Whistle
Post #529934 8th May 2016 1:21pm
Happyoldgit
This is nothing new and the screen to bulkhead seal has been a potential problem area since the introduction of the 90 & 110 back in the '80's. Steve.
http://forums.lr4x4.com
Post #529978 8th May 2016 6:22pm
nickhodgson
And there have been lots of different part numbers for that seal....... 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #530116 9th May 2016 2:05pm
Happyoldgit
...and the quick cure is to pull the door seals out and run a bead of sealant along the entire join including around the ends / corners where the door seals fit. Steve.
Post #530137 9th May 2016 3:53pm
