Home > Technical > how to connect a brake control system in the Puma?
Eduardo
Hi there!
In a hurry before start the trip...
I need t connect the typical RV electronic brake control system in the Puma.
This one
Any Thought about how I can do it?
Thanks in advance Eduardo
Post #52929 14th Jan 2011 11:46am
Lorryman100
These are not commonplace in the UK. UK spec trailer brakes are mechanical rather than electrical, which is the standard fitment in the USA. You would be better to try the American forums for a fitting guide unless you have the wiring diagram for the unit, then I'm sure some one on here will come along and help Thumbs Up
Post #52932 14th Jan 2011 12:26pm
Eduardo
Thanks lorry,
The diagram said the following:
Red: to the stop signal with a 20A fuse
Black: to the Battery possitive with a 25A fuse
White: to the chassis ground
Blue: to the trailers brake (pin 7 in the US system)
Main problem is: In the 12N plug the pin assignation is as follows that differs from the american system
1.- Turn left
2.- Fog lamps
3.- Ground
4.- Turn rigth
5.- Position lights left
6.- Brake ligths
7.- Position ligths rigth
American system is
1.- Ground
2.- Position ligths
3.- Turn right and brake
4.- Reverse
5.- Turn left and brake
6.- 12 V battery power
7.- Electric Brakes
What shall I do?
Looks that the best alternative is a direct connectios Sad Eduardo
Post #52961 14th Jan 2011 3:24pm
Lorryman100
Eduardo wrote:
Thanks lorry,
1.- Turn left
2.- Fog lamps
3.- Ground
4.- Turn rigth
6.- Brake ligths
American system is
1.- Ground
2.- Position ligths
4.- Reverse
7.- Electric Brakes
What shall I do?
Do you also have a 12s plug? If so use one of the 2 spare pins, no 5 (brown) and no 7 (black) that way you have a permanent solution!
UK spec Trailer plug wiring:
'N' type
Yellow :- L/H indicator
Blue :- Fog light
White :- Earth
Green :- R/H indicator
Brown :- R/H tail / side light
Red :- Brake lights
Black :- L/H tial / side light
'S' Type
Yellow :- Reversing Light
Blue :- Ignition 12V supply
White:- Earth
Green :- Continuous 12V supply
Brown :- Spare
Red :- Fridge
Black :- Spare
The only other option I can see is to disconnect the fog light and use this connection on the 12n plug as the fog light is the least used!
HTH Brian Thumbs Up
Post #52970 14th Jan 2011 4:32pm
Eduardo
Thanks Brian,
I have the 12S, so probably I will use one of the spares.
Main problem is to have a trailer that is not standard in the brake system Sad
Cheers. Eduardo
Post #52986 14th Jan 2011 6:27pm
jst
can't you just make up a short adaptor lead with Male one end and female the other that switches over the pins and takes your feed through for the electronic control box? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #53028 14th Jan 2011 9:06pm
Eduardo
Yes I can do that but with 3 plugs the thing will look like a space connection module of the orbiting station, and the probablitoty to forget to connect the plug will be higher.
Thanks again for the recomendations Eduardo
Post #53054 15th Jan 2011 1:35am
mse
Not knowing how it works.
Cant you take it from the brake light feed with the brake lights?
America their brake and indicators are often on in the same Mike
Post #53081 15th Jan 2011 11:53am
Lorryman100
_________________
The wire Eduardo is concerned about is the feed from the vehicle mounted accelerometer to the brake module on the trailer which controls the braking force applied to the trailer brakes.
Post #53179 15th Jan 2011 7:50pm
AndrewS
Eduardo
Did you sort the wiring Question 130's have feeling's as well you know Smile
Post #66940 11th Apr 2011 9:12pm
Eduardo
Well
Finally and due a bad installation of the 12S socket (I cannot take out the socket and only the fridge was connected Evil or Very Mad ) I use a 3rd standard american plug to wiring the brake control, the 12V for the battery and the reverse light.
By the way, the electric brake control requires at least 10AWG wiring
Cheers Eduardo
Post #66954 11th Apr 2011 10:11pm
