Home > Td5 > cutting out and water guage jumping into the red
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Yesterday morning my td5 90 was hard to start and occasionally whilst turning over the guage would jump to the red.
Today it started fine but has been cutting out on the way to work. When it does die the yellow engine warning light comes on and the water guage does off into the red. twice it lasted about a second and came back to life. The third time it died for about 20 seconds and the guage stayed right off the top. when it dropped down the landy started 1st time.
I'm guessing an earth fault and I've had some advice to the same. Anyone else ever had this? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #529544 6th May 2016 2:28pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Think I already replied to your Facebook thread. Run a new earth, check ECU plugs and relays for corrosions and ensure they're making good contact
Smile
Post #529547 6th May 2016 2:34pm
gazman
yes you have mate. I was talking this through with a colleague at lunch and he told me to post the same question on a forum over Facebook as he said forums tend to be more knowledgeable.
I'm with you though, but just incase it's a common fault and as I'm going to be doing it on the high street at 7pmm I front of all the pubs and drinkers I want it sorted as quick as I can! 2014 - current ..... 2003 defender td5 90 (my car)
Post #529549 6th May 2016 2:56pm
huffhuff
I find Facebook good for a quick response...
...forum best for a more thoughtful, sometimes more accurate response Smile
Post #529550 6th May 2016 3:01pm
landroverdiver
Same thing happened to me, it was oil in ECU plug
Post #529553 6th May 2016 3:13pm
Steve Sidebottom
England 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
This happened on my old TD5, one of the yellow relay under the drivers seat had poor contacts. A clean with contact cleaner and a squeeze of the slot terminals and all was good again.
Post #530125 9th May 2016 3:21pm
gazman
looks like your bang on the money Steve. I relocated my fuse box and ecu from under the drivers seat, everytime I knocked or moved the main relay the fault occurred.
cleaned the contacts and squeezed them and all is good again 2014 - current ..... 2003 defender td5 90 (my car)
Post #530189 9th May 2016 6:45pm
gazman
double post..... 2014 - current ..... 2003 defender td5 90 (my car)
Post #530191 9th May 2016 6:48pm
huffhuff
What I said in the first reply then Smile do I get a prize?!?
Post #530194 9th May 2016 6:51pm
gazman
you get the smug satisfaction of knowing you were right, and the double factor of knowing that I then didn't quote you as being the 1st correct one! 2014 - current ..... 2003 defender td5 90 (my car)
Post #530242 9th May 2016 8:37pm
huffhuff
Well I'll PM you my email and you can send me some Amazon vouchers or something Smile
Glad you got it sorted... Fingers crossed it wasn't one of those annoying intermittent issues
Post #530258 9th May 2016 9:04pm
gazman
if I ever bump into you their is a pint or two on me Wink 2014 - current ..... 2003 defender td5 90 (my car)
Post #530267 9th May 2016 9:28pm
