![]() | Home > Maintenance & Modifications > Switch recepticles |
Motoberg Member Since: 01 Oct 2015 Location: Aberdeen Posts: 104 ![]() ![]() |
N16kct Member Since: 24 Aug 2015 Location: Oxfordshire Posts: 151 ![]() ![]() ![]() |
Hi think they might be the ones
![]() I wonder if they will house oe switches ? |
Those switch mounts are for Carling switches which are a different size to most/all OE switches
Brendan |
Are there any available for oe size switches?
It depends what exactly it is you are trying to achieve? You could try the scrap dealers as the Defender OEM switches can be found in other marques and you could possibly source a housing there perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Basically, I am doing a double din install and I don't want to cut a hole in my dash, I'd rather relocate the switches elsewhere.
I did think about looking at various rovers/mg but ipthere aren't many places you can wonder around anymore. I might get a friend to draw me some and have them rapid prototyped at work that way I get exactly what I was looking for ![]() |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
If you are only talking one switch, the Defender spotlight kit has a switch & included is a OE item for inserting it in the dash.
Pickles. |
It's going to be a few iirc and the hazard warning switch. Never mind I had hoped there'd be an off the shelf solution, but its not the end of the world as I can get them made easily enough it'll just cost me some beer tokens
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
mcma1 was looking at 3D printing them..
If mcma1 is not doing them yet you can buy doubles from Firstfour: https://www.firstfour.co.uk/item/2177292/d...tch-bezel-
However the hazard switch is too big to fit these, you might have to change to a Disco2 hazard switch (which is the same size as the normal Defender switches). Pretty sure someone on here detailed doing these recently? ![]() ![]() |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5135 ![]() ![]() ![]() |
Early Defenders had a smaller hazard switch part no YUF101490 ![]() http://www.youtube.com/user/conwy1 |
I think that'd do it Martin thank you very much!
I've suddenly got 3 extra switches and less holes to put them in! And as I say, I just can't bring myself to cut holes in my dash! I will look into the hazard switch, thanks chaps |
That pre-2002 hazard switch is not a standard Puma size.
Yes I know that
