![]() | Home > Puma (Tdci) > Dash Clock - Problem |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Replaced the bulb in mine and now it's slow...
Out of warranty - new clock is £50. Weee bit boring, would rather have one on-time that I cant read at night, compared to one that is wrong. Solved the bowel problem, working on the consonants... |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
have you made sure that while you have had it out the clear face hasnt become dis lodged and is pressing on the fingers slightly?
when i painted the surround it took me a few attempts to get the clear face to sit properly |
| LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411
If you are gaining minutes, then I have no explanation.... but if you are losing minutes, then it may be a result of going too fast relative to stationary clocks...
| strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401
Funny you should mention problems with clocks. I am still having problems with Land Rover customer services. The clock in my 90 did not change to British Summer time again this year - who do I complain to?
| Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971
Weirdly, mine adjusted itself forward an hour today!?
| Panda Member Since: 29 May 2015 Location: Essex Posts: 432
A Timely Comment, I will watch this thread
Yoda Disco 3-Sold Larry Disco 1-Sold Muddly XS 90 TDCI-Sold Pearl Disco 2-Sold Larry Disco 1-didn't want too but sold |
Looking at it for a full 24hrs* I noted that it would occasionally make an attempt to move a minute but kinda hiccuped/farted at the same time and got nowhere. Sometimes taking 4 attempts at these 'boss' times.
Running it round and round using the + button didn't blow out the cobwebs. Doesn't look like the hands are touching the cover but cant rule it out. I'll pull it out and run it on 12V inside the house and see what happens... If it's still farty, I dunno, contact cleaner or WD40 in the mech? *looking at it at the lights... Solved the bowel problem, working on the consonants... |
| Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178
It was replaced ... no questions from the dealership on space time or Einstiens theory of relativity! Quite a relief actually...I was ready for a long debate with JLR that a Defender moving faster does not equate to time slowing down....my dear old beast does not even get close to the speed of light
| rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296
That'll teach you not to drive too close to a gravitational singularity again
| tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129
my clock is never accurate.....I am planning to remove it and put a boost gauge there.
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391
I'm thinking of replacing mine with a digital display and a 3D printed surround / bezel...
I really don't like "tick tock" clocks.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
Took it out and connected it to a bench DC supply for a day without the plastic cover. Didn't lose a beat over 2 days...
So it turns out I installed the clear plastic and the seal in the wrong order. I shouldn't have even taken it off in the first place, but I assumed it'd need taking apart to get a new bulb in there... So the clear plastic has a rebate in it that looks like it's made for the seal, but nooooo, other way round chap! With the wrong assembly order the plastic juuuust touches the hands which gives juuust enough friction to lose me a minute every 50min on average. Solved the bowel problem, working on the consonants... |
