![]() | Home > Maintenance & Modifications > Rear ladder and Numberplate |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Hi Guys,
I want to fit my rear access ladder permanently as I don't like the idea of having to unbolt and re-bolt it every time I want to use the roof rack. Problem is, when fitted on the passenger side it partially blocks the number plate which is not so good. I can fit it on the other side but this will require a modification to the mounting slots in the ladder. What do we think? ![]() Click image to enlarge ![]() Click image to enlarge Passengers side Blocking number plate ![]() Click image to enlarge ![]() Click image to enlarge Drivers side not blocking the number plate Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1875 ![]() ![]() ![]() |
Can't say I've ever heard of anyone having issues with the authorities and the ladder obscuring the number plate, but you obviously have a doubt otherwise you'd just fit it to the other side.
All depends how big a modification is needed to the ladder to get it fit 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7932 ![]() ![]() ![]() |
If you were worried you could weld in a loop around the number plate?
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
Hannibal roof rack, full height ladder, been there for 16 years and 180000 miles!
[URL=] ![]() Click image to enlarge[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Or just move the number plate to the other side?
Thanks guys for all the replies.
![]() As it will only need a slot cutting in the mounting bracket I think I will just put it on the drivers side and then forget about it. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Don't forget though, if lifting items onto and off the rack whilst partially on the ladder, if you are right handed that will be a pig, and I think hence why ladders are more commonly on the left? If you are a leftie though, then its a bonus. North Cumbria Search and Rescue - Team Leader
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 886 ![]() ![]() ![]() |
"I think hence why ladders are more commonly on the left"
I think it's 'cos if they were on the right the door-mounted spare wheel would bash into them! But I had a Brownchurch roof rack/ladder which partially obscured the number plate, never had a problem with MOTs Peter |
Yep other than the obvious rear wheel haha!
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
i think they are generally on the left so you can use them with the rear door open DEFENDER 90 TDCI XS,
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 ![]() ![]() ![]() |
Spare wheel will foul if ladder is on right side. Regs are quite ambiguous and I think just says plate must be visible from the rear. Yours is.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
Ladder may also foul the door if on the offside.
