Home > Wheels & Tyres > Spacers
Page 2 of 3 <123>
Cupboard
Thumbs Up
The issue that I speak of is that late model 70 series Land Cruisers have a narrower track in the back than they do in the front. I think the difference is 10cm but I'm not completely sure about that.
Post #527236 27th Apr 2016 8:29am
Def Junkie
Any views on alloy or high grade aluminum spacers? I've gone with aluminum but then someone said alloy would have been better. This is just for my peace of mind.
Post #527983 30th Apr 2016 7:54am
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
"High Grade alloy" is just marketing bumph and doesn't actually mean anything.
There are dozens if not hundreds of different aluminium alloys specified by different standards.
Your spacers are almost certainly an aluminium alloy rather than pure aluminium. Thumbs Up
Post #528030 30th Apr 2016 11:14am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
Hi all,
Kind of a thread hijack, but anyway...
Anyone know if you can replace wheel bearings with 30mm spacers still on the hub?
Post #543195 25th Jun 2016 12:50am
Very unlikely and only if the spacers were a completely rubbish design.
Decent spacers will have a centre boss to locate the wheel which will partially encapsulate the drive flange or halfshaft end. With these you cannot remove the hub.
Very cheap spacers may not have the boss and with these you might be able to.
Why would you want to, by the way? Five nuts to remove the spacer- doesn't take long!
Post #543244 25th Jun 2016 10:52am
Arierep
Plenty of spacers from reputable suppliers are not hub centric. Since the nuts have cone seats, and assuming a proper tightening pattern, I don't see many advantages with an hub centric design, but I might be missing something here.
Anyway, why do I ask? I would never install spacers without locktiting the studs. Since loctite is not always available it would be nice to keep the spacer in place in case I needed to remove a flange, halfshaft or bearing
Post #543323 25th Jun 2016 4:17pm
Jose.Pereira wrote:
... I would never install spacers without locktiting the studs...
Why?
Correctly tightened you won't have any trouble with them loosening.
Post #543330 25th Jun 2016 5:01pm
Arierep
Peace of mind.
The nuts are not visible for exterior inspection. And driving all day on corrugations does wonders, I even had a door come loose one time
Post #543331 25th Jun 2016 5:03pm
Fair enough! Thumbs Up
Post #543352 25th Jun 2016 5:57pm
Arierep
So the consensus should be that with non hub-centric 30mm spacers it is possible to change the bearings with them on?
Thanks
Post #544739 30th Jun 2016 8:28am
Cupboard
If you're taking enough tools and parts to change a drive flange or bearing, you could always throw a tube of Loctite in too? I'm pretty sure I remember one of the sets of bolts, potentially the drive flange ones, needing some sort of thread locker on them anyway?
Post #544780 30th Jun 2016 10:13am
Arierep
One more quick question on spacers.
I know that Simonbbc (Bulldog) says that hubcentric spacers are not compatible with HD flanges.
However I've seen some pics of hubcentric spacers with HD flanges (don't know the brand).
Any experiences with this?
Post #561745 5th Sep 2016 10:22pm
For quite a while ran Rakeway 30mm spacers with Ashcroft HD flanges with no problems whatsoever.
Post #561752 5th Sep 2016 10:50pm
mk1collector
Terrafirma spacers fit with britpart hd drive flanges Ray
My build thread
Post #561755 5th Sep 2016 10:52pm
Arierep
Thanks
Can you remove the flange or the hub with the Terrafirma ones installed?
Post #561845 6th Sep 2016 1:32pm
Page 2 of 3 <123>
