Home > Puma (Tdci) > Speed bump - transmission loss and veering to side
Doubledoom
United Kingdom 2016 Defender 90 Puma 2.2 SW Santorini Black
I have noticed that when going over larger speed bumps, i lose transmission momentarily and the vehicle suddenly veers to the left but everything returning to normal. The noise underneath sounds like a bag of spanners sloshing around in water before carrying on as normal.
I have wondered if it is the DSC kicking in but the veering to the side is quite strong. Does anyone else find speed bumps are an issue?
Post #527956 30th Apr 2016 12:46am
Balvaig
This happens to me too, but I do not get any change of direction. Slight power loss and traction control firing up, which is the sound you hear.Dsc seems very sensitive fo speed bumps.
Post #527990 30th Apr 2016 8:29am
Roy5695
If i remember correctly there has been reports of the looming being chaffed in a certain area, maybe this could be your problem, going over the speed bump moves the cable and shorts activating traction control?
I'm pretty sure there is a thread on here somewhere about it...
Post #527991 30th Apr 2016 8:35am
Balvaig
In my case I am hoping it is normal and just over sensitive DSC. My Defender is an Oct 2015 Landmark. Low mileage so hopefully not chafing. Commented because veering seems a problem that should not happen. No expertise from me, as previous 2011 Defender did not have DSC.
Post #528002 30th Apr 2016 9:19am
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
Balvaig I also have a oct 2015 landmark and it does exactly the same thing.
I don't get it pulling to one side but the DST definitely kicks in as you get the loss of power from the DST cutting in as you go over a bump.
Traction control from what I've learned does not cut the power it simply applies the brakes so if you're getting lack of power when you put your foot down that is the DST.
Try turning the DST off on the dash and then drive over the bumps and see if it still happens? -2015 Defender 90 XS Landmark-
Post #528014 30th Apr 2016 10:10am
Doubledoom
The veering may actually be because the speed bump it always happens on is on a bend and the steering wheel is to the right. It is only momentary. Veering is probably too strong a word.
I will have to go into town as they have some short stumpy bumps there in a straight line which will almost certainly cause it to activate. See if the movement to the left happens there. Then try it again with the DSC turned off.
Post #528025 30th Apr 2016 11:03am
toby9946
Good luck!
I'm not too bothered with mine doing it and seems mine isn't the only one, I just think the system is a little overly sensitive.
If it gets worse I will have to talk to the dealer though..... -2015 Defender 90 XS Landmark-
Post #528027 30th Apr 2016 11:10am
Cheshire110
The loss of power is normal, it's the DSC doing its thing. It happens on other cars too just less noticeably because they are, shall we say, "less quirky".
Mine doesn't change direction at all though, and there's no reason that it should really Cheers, David
Post #528028 30th Apr 2016 11:11am
LoveTheMud
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Santorini Black
Yeah it's just the traction control...bip the clutch momentarily and it won't do it,
Post #528032 30th Apr 2016 11:23am
Cheshire110
I've got into the habit of knocking into neutral when I go over a significant speed bump anyway, stops the jerky throttle response when your foot moves around Cheers, David
Post #528037 30th Apr 2016 11:48am
