Home > Technical > Current draw from alarms and other electrical items
Bps
Just wondered what sort of current accessories fitted to defenders are drawing without the ignition on. For example my alarm and flashing warning lights are pulling between 20 and 35 ma depending on what's flashing and if you trip the movement sensor.
Post #527917 29th Apr 2016 9:31pm
Most are around the 30 - 45mA region I would have thought.
I once had an issue with a wrongly wired relay. (Dealer sold it like that!)
The issue was the coil in the relay was permanently live, it shouldn't have been and was drawing about 200mA at rest.
That was enough to cause starting problems / starting failiure after about 2 days of not being used I think.
H/U's also tend to draw a small current at rest but normally 2mA - 20mA I would estimate.
Post #527926 29th Apr 2016 10:05pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
If I remember rightly - Battery Life = Battery Capacity in Milli amps per hour / Load Current in Mill amps * 0.70
75 amp per hour battery with a 45ma load should dissipate in around 1100 hours if this was the only load.
75 amps = 75000 / 45 x .7
Around 45 days dependent on temperature and loadings Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #527958 30th Apr 2016 1:19am
