![]() | Home > Maintenance & Modifications > Tarox Brakes |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
I have big brakes too, i was told during development they tried numerous callipers (both front and rear) with different size pistons to retail a similar pedal feel..
mine feel great.. I'm guessing someone did some development with the tarox brakes? did you get the 6 or 8 pot fronts? |
| Bristol 90XS Member Since: 31 Oct 2010 Location: North of Bath Posts: 223
well I would hope Urban Truck have done some as they are using on a V8 they have!!
The combination is 6 pot front and 6 pot rear, rear disks are supposed to be smaller and designed for rear according to TMD. What combo is in yours? And what make did you fit? Thanks for reply, James |
hmm maybe urban changed the master cylinder on the v8?
i thought tarox used standard discs? i'm personally not a fan of tmd but will leave it at that.. I've got ap racing, 6 front 4 rear 360 disc front i think 298 rear? |
How does that setup work?
It was a long pedal with just 6 pistons on there already but these brakes are marketed for Defender so shouldn't need an upgraded master cylinder to make them work!!! James |
| YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648
It shouldn't need an upgraded master cylinder... says who?
Given the huge volume increase you have made over the additional system, I would be amazed if the OEM master cylinder was up to the job. Been there, done that with the Lotus days. These 'improvements' need ground up engineering to be properly successful IMHO. Almost reverse engineered to really make it work properly.. And then, you fit the bigger master cylinder... then you find the brake bias is off... so then you get a bias valve fitted... etc etc! Hope you get it sorted... |
Thanks YOLO!!
Says me To pay a large sum for an upgrade which is marketed as such should be just what it is!!! Interested about what you did on Lotus before though sounds impressive!! James |
is it spongy or just long travel?
i tried experimenting (mountain biking) with lightweight levers and more downhill focused callipers on one bike, the servo lengths etc weren't suited and in the end had less stopping power than a standard cross country setup had to really use the full travel of the leaver... now time has moved on a bit and everything is enduro Im no expert just chiming in my experiences... |
| Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214
Enduro ftw
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3802
Brakes,...VERY important!!
And, they have to work, PROPERLY. And that is why a properly engineered kit is the answer. If a brake kit is produced by reputable people, and marketed specifically for a Defender, then that "kit" should be all that is required, unless of course there are conditions attached to instructions relative to fitment. In Aus, we don't see much of this stuff for Defenders, but there's HEAPS & HEAPS of it for Ford & Holden V8s, marketed by various companies. These companies do all the testing R & D etc, so that when you buy the kit, it works well with your master cylinder, brake fluid pipes, bias etc etc,.....which doesn't happen if you cobble up a combination of stuff yourself. Pickles. |
@Likeomg - it's spongy with longer pedal travel but if you pump once it firms up and feels better but still not right.
@Pickles - kit is marketed for Defender with no mention of potential extra kit required or potential for this scenario I'm posting here to find out if anyone has done this, had same issues and has overcome the issue... |
| Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288
Have you driven far enough to allow the brakes to bed in?
Yes have done about 1000 miles on fronts to let them bed in. No difference since fitting rears and having system flushed through to remove any air.
Seems strange that no one seems to have fitted these brakes - loads of people sell them! James |
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502
Take it UT and get them to sort it? 1951 80" S1 2.0
earlier today..
Click image to enlarge |
| All times are GMT |
