![]() | Home > Puma (Tdci) > Puma Rear diff noises |
| Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216
Same problem my 110 my09 with 50k km on the clock.... They have changed twice the rear diff with a recon, after I complained with the LR costumer service, LR sent a flying doctor to the service garage where my 110 was, he spent a day (together with two others mechanicals....) to dismantle and overhaul the 2nd diff changed, things were better but it still made noise, therefore the flying doctor allow LR to send a NEW rear diff. Now it's ok, but they took 1 month and a half to solve the problem... Defender 110 Td4 SE MY 09 |
| Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231
ok......
all sorted......by me. I tried the tranmistion wind down - low range reverse, snake stearing....and violaa- fixed. Then layter I low ranged again and the noise came back.....#@#$#$#@. Then I tried to unwound transmition with no luck. Later I was at a trafic light and it jumped out of high into neutral all by itself. Back in, noise still there. Later back into low - back into high. Then I coasted slowly faward putting pressure on the lever and it "clicked in" just that little bit more. Noise gone!!!! Then I started figuring that perhaps the tarnmision wasn't in gear all that well. It will drive, but with a noise..... Later a friend informed me that you should keep in gear (h-l) neutral, then rev a bit and then angage between (l-H. |
