Home > Puma (Tdci) > Faultcodes
mees
Netherlands 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Faultcodes
Hi,
I'm on holiday and it feels that the car is more sluggish and also fuel consumtion increased (8km per litre)
I just fitted goodyear wrangel Mt/r tyres and a roofrack so this could contribute to it, but was not certain.
Therefore i checked for faultcodes and found the following codes:
0100
0299
0404
1103
I was thinking the Egr valve, but it's doing the chakka chakka noise and no Mil illuminated.
Any ideas?
Post #527049 26th Apr 2016 6:40pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
0100 is related to MAF sensor, poss disconnection ?
0299 is turbo underboost
0404 is an old favourite, EGR range. most common [and meaningless] 'fault' out there
Can't find a 1103 ???
Clear them all and see what reappears in a few days ....
Good guide here, just put in your code and it gives you an explanation and possible causes/checks Thumbs Up
http://www.obd-codes.com/ Guns and Landrovers .... anything else is irrelevant.
Post #527137 26th Apr 2016 9:14pm
I think off the top of my head, but don't quote me that 1103 is MAF related also.
It's also widely considered that EGR codes can cause MAF codes but not vise versa.
If no MIL I wouldn't worry at all, but I wouldn't delete the log of DTC's.
Post #527146 26th Apr 2016 9:29pm
Dave-H
Correct, 1103 is MAF sensor signal higher then expected Wink
Need to delete to see if any re-appear, how else will you know if they are genuine faults or just 'nuisance' triggers .. Guns and Landrovers .... anything else is irrelevant.
Post #527150 26th Apr 2016 9:41pm
If they reappear wouldn't that trigger the MIL.
Suppose only a continuous fault would trigger the MIL though not a constant intermittent.
Post #527162 26th Apr 2016 10:00pm
Cupboard
Not necessarily, mine sometimes goes in to limp without lighting the MIL, sometimes the other way round and sometimes both together.
If it's causing issues then I'd suspect the EGR valve, if not then I wouldn't panic. New EGRs are about £150-£200 plus fitting (not technically difficult, but very fiddly), getting the EGR system disabled and blanked is about £120 and removes a common fault.
Post #527301 27th Apr 2016 12:45pm
mees
yesterday drove around 100 km and only the following fault codes showed up again.
p0404
p0100
but it seems that the car is running better, also fuel consumption better now.
so i"m expecting the EGR valve.
Post #527734 29th Apr 2016 10:36am
Did it give you any further info such as 'restricted' 'stuck open' or similar?
It would likely be one or the other, if running better I'd imagine it could be sticking closed.
Have you been able to try any additive at all?
Post #527737 29th Apr 2016 10:44am
mees
no further info, only the 2 DTC's
did not use any additives, but drove 700 km, 500 km and tomorrow again 750 km. So may be the long distance is cleaning the EGR valve a bit
Post #527827 29th Apr 2016 4:57pm
It would do, short journeys aren't good with the EGR.
Similar with the DPF I believe too.
Post #527828 29th Apr 2016 4:58pm
mees
Today came back from Italy. The journey went very well and fuel consumtion was ok now.
But when arrived af home the shukka shukka noise was very loud and strange.
So now 100% sure it is the Egr valve. luckely I was home already Very Happy
Will contact the dealer for replacement.
Thanks for al the replies.
Post #529848 7th May 2016 10:44pm
You could change it yourself?
Post #529850 7th May 2016 10:46pm
