![]() | Home > Td5 > Eberspacherfiller neck fuel take off |
| chopcat Member Since: 11 Sep 2012 Location: Pembrokeshire Posts: 414
Has anyone installed a filler neck fuel take off for an Eberspacher?
http://www.bowerspartsonline.co.uk/brands/...pipe-20300 I would be interested to hear if it went ok |
| Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230
I bought one of these when I heater my heater (supplied by MV Heating). I bought a new connecting pipe as well and fitted it in that. Works well and was easier than removeing the fual tank etc. Remember to buy the extra clips to secure it.
| trooper Member Since: 11 Mar 2014 Location: west sussex Posts: 102
In my TD5 90 I have an additional fuel tank fitted, which connects into the filler pipe. Will there be sufficient space to fit the eberspacher neck fuel take-off as well.
| shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347
I have a earlier tank with a spill off pipe blanked which I used for my install.
I did consider this but the cost put me off but looks a dead simple fix. Only issue is if you want to add a wing tank then it wont quite fit apparently, which again was a consideration for me but may not be for you Self confessed mileage hunter |
