Home > Puma (Tdci) > Brand new 110 XS Puma losses power
Page 2 of 2 <12
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Same here
Had exactly the same problem, picked up new 110 xs utility from marshalls peterborough, on way back to northampton experienced power loss several times, phoned dealer who asked me to bring it in the following morning.
Took it back and was told nothing wrong with it, sent me home, same fault on way home so had landrover assit out. Had to drive him round for 2 hours to simulate fault whilst diagnostics pluged in. Faulty thermostat turned out to be the problem, they did not have one so they gave me a courtesy vehicle and recovered 110 to peterborough to fix.
Collected it and had to complain to get them to put the fuel in it they had used, and to cap evrything land rover assit scratched the dash with their laptop, New Dash fiited,
Post #51346 6th Jan 2011 2:16pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Re: Same here
Once when my first Puma broke down it was recovered to hartwells in Nothampton. Normaly I would not go near them but as I had just pulled out of a garage (two miles away) after filling up when it died I had no option. Anyway I got it back two weeks empty and with only about 2 gallons left in it. What a row I had with them, they were so rude and in the end just told me to leave or else. I will never go there again!
Post #51349 6th Jan 2011 3:17pm
MK
So a bad thermostat does not kick the MIL light? Shocked Puma 110" SW
Post #51352 6th Jan 2011 3:28pm
kingofthesparks
Temp gauge did not go into red , only went 3/4 up .
Post #51356 6th Jan 2011 3:50pm
hcs
South Africa 2007 Defender 110 Puma 2.4 CSW Alpine White
My first post on this site. Very Happy
My 2008 Puma does exactly the same. Just a sudden loss of power. It can happen from start up, while driving, pulling away etc.
No warning lights, no smoking or yerking.
Also no rise in temp on the gauge.
Only way to get it back to normal, is to stop, switch off and back on.
I do notice however that it seems to be worse when its really hot outside. In winter I havent had this problem.
Stealers just scratch their heads, can be this, can be that. But no fix yet
Post #52695 13th Jan 2011 9:15am
MK
Did he investigate the EGR valve? Puma 110" SW
Post #52697 13th Jan 2011 9:37am
hcs
AFAIK they looked at the EGR, but it seemed to be fine.
And they guy said its still making the "right" noise when shutting down the engine
Going in again today perhaps to have them do a diagnostic again. Last time no faults came up, apart from a dirty ABS sensor on the right rear wheel
Post #52698 13th Jan 2011 9:47am
MK
have the same and the scanner did not detect anything! I can not drive it for the moment, but after consulting dgardel, it would be a good idea to clean some sensors (MAF, MAPT, fuel pressure, etc). Puma 110" SW
Post #52703 13th Jan 2011 10:02am
Naks
This problem (esp when it's hot) is symptomatic of the presence of a ceramic plate on the turbo inlet hose. On the later model Puma this have been removed, allowing a metal plaque to close/open.
HCS, give Fanie a call at LR N1 City, he will be able to explain it to you in more detail. The last time I was there he looked at my engine bay and told me that mine is the updated version and should not have this issue.
Post #52795 13th Jan 2011 5:52pm
MK
ceramic plate on the turbo inlet hose?
can you explain more plesase? Puma 110" SW
Post #52804 13th Jan 2011 6:38pm
Naks
this from the technical guy at my stealer:
Quote:
We found on some cars that the wires on the turbo modulator plug pull out due to stress on the loom or engine vibrations. So they move the ferrite further down the loom. So if there is issues with the pins on the plug you must renew the plug with pins.
Post #53448 17th Jan 2011 4:18pm
Page 2 of 2 <12
