Home > In Car Electronics > Double Din Dash
saltydog
2015 Defender 110 Puma 2.2 USW Corris Grey
Double Din Dash
Can anyone let me know who is the best to supply and fit a double din dash to my Defender. PM me if you are doing this to discuss. Cheers LR Defender 110 XS Utility Wagon
LR Discovery 2.0 Sport HSE
LR Discovery 4 Landmark
Post #525872 22nd Apr 2016 7:43am
Stiff1
There are pretty much only two suppliers now.
Ones you get with the side panel all seem to come from the same manufacturer so just get the best price you can.
Twisted also recently released their own version which has the dash and vents all in one (the others, you must cut your existing vents and clock off). I also believe it is only in gloss black but they may now have expanded the options.
Standard unit with side panel costs the ridiculous sum of approx. �300
Twisted one is considerably more but has the convenience of no cutting so your existing dash can be sold on intact.
Fitting is very simple and rewarding, do it yourself.
This is mine.
Post #525978 22nd Apr 2016 3:15pm
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
The Twisted dash will set you back a cool �600 but it is the best there is out there. It also has the advantage that it comes with the loom to extend the hazard switch so fitting is pretty simple.
some pictures on my thread here: http://www.defender2.net/forum/topic42084.html
Post #525989 22nd Apr 2016 3:40pm
blimbug
United Kingdom 2009 Defender 110 Puma 2.4 SW Bonatti Grey
The alternative is to get a stereo with a flip up screen, meaning you can use the single DIN slot, but still get a large (7 inch) screen.
I'm just in the process of fitting this one:
http://xtrons.co.uk/d766a-7-android-4-44-k...-obd2.html
And i'd highly recommend it!
I'll get round to putting a write up at some point...
Post #526027 22nd Apr 2016 5:48pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
But if you want Apple CarPlay it has to be double din. No flip up models.
Post #534739 26th May 2016 12:51am
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Available in Matt black or Piano black. Expect to pay around �240 Thumbs Up
Post #534748 26th May 2016 6:52am
When fitting a DD dash and using the supplied switch plate that sits to the right, there is no need to extend the cable on the Hazard switch or any other of the top row switches, they are all long enough if you unwrap some insulation
Post #534759 26th May 2016 7:33am
