![]() | Home > Technical > Rear Tyres worn on inside edges in 4000 miles |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291 ![]() ![]() ![]() |
A friend of mine has just called saying he has both rear tyres with exceptional wear on the inside edges after 4000 miles, its a 110 running Grabber AT3's on Boost rims, he is checking for worn Bushes and Wheel Bearings, any ideas as to what could be causing this, NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
I think you have already nailed the likely suspects;
Bushes - worn could cause four wheel steering leading to excessive wear. Bearings - if worn could cause the wheel to not run true, but I would expect wheel wobble to be felt if this was true. Extreme Thought, but bent axle?! |
