![]() | Home > Puma (Tdci) > Central locking & electric windows |
ParabolicSwivel Member Since: 13 Nov 2013 Location: Hertfordshire Posts: 42 ![]() |
Hi
I'm also in the process of fitting central locking. Doesn't look like big a challenge except maybe fiddling with the alarm system since the version I have doesn't have the necessary relays fitted. For now I'm going to leave it working independently of the alarm. There is a ton of info in the forum archives - try a search and you'll come up with great stuff like this: http://la7dja.org/defender/cdl/ No idea about the Windows though. TTFN |
110UTEGP Member Since: 20 Apr 2016 Location: Johannesburg Posts: 4 ![]() ![]() ![]() |
Hi.
Got windows sorted.....wiring harnesses for the windows and central locking are already factory fitted (Found them hidden in "A" post, plugged in door harness and windows work fine ![]() Land Rover have said I need to swop out control module behind dash to get central locking working........ Cheers ! |
technically they're right, but people have had a lot of success just attaching the missing relays.
The unit is the same with or without central locking, it's just whether the central locking bit is actually there. It's not hard to add by all accounts. |
Thanks for the heads up, any idea where relays are located ?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6684 ![]() ![]() ![]() |
The missing relay is inside the green 10AS unit, I've just upgraded the one in my soft top 90.
However a 2016 Defender has the newer alarm system so I don't know whether these are similarly upgradable ![]() ![]() |
Thanks........the quest continues !
Ah, I hadn't realised that ![]() When did they change and what do they use now? |
Simon.pl Member Since: 15 Mar 2016 Location: Warsaw Posts: 98 ![]() ![]() ![]() |
Sorry for resurrecting an old thread, but I don't want to create a new one.
If I have the relay inside the 10AS unit, does it mean that the Central Locking should work after attaching actuators to the wires that ends just at the entrance to the front door? I've been installing aftermarket central locking system and want to use factory wires. Just made a short test with the fob and the only thing I get is horn that goes on once, but that is ok as there are no door switches installed yet. Should the actuator work even knowing that the doors are not closed, or all doors must be closed to acitivate the central locking? Mine is MY2007 110HT ![]() |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Just a question....I have a my2015 90 ....is it a simole job to add another extra actuator to the original setuip..do you just piggy back onto one of the door actuators ...or is it more complicated!
How did you upgrade the unit? By adding external relay, or there can be one soldered inside? Cheers |
have a look at the link below
https://www.technozen-electronics.co.uk/la...-services/ |
Cheers Dorsetsmith
Wish I new about this page before I reinstalled my unit and dash back in ![]() Had everything in pieces for almost a year! Well - need to check precisely what part no my unit is. There is NEC relay inside, but have no idea what "associated components" mean.. And at the end it may appear that it was not programmed to have CL active ![]() |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Seems the black 10AS modules are not that easy to add central lock to. I also found this out the hard way. May need to go to the dealership for insight on how to program and install the wires... I have the 5wire actuator on the front doors and 2wire on the rear, so from the keyhole i can lock and unlock the doors. However, a more luxurious install is using the remote. |
24heuer Member Since: 21 Jul 2015 Location: Edinburgh Posts: 175 ![]() ![]() ![]() |
Hi,
I'm going to have a go at retrofitting genuine central locking to the front doors of my '09 110 as it looks like I have the connectors hanging loose in the A-pillars already. ![]() I'm just trying to price it and putting together a parts list I have the following - looks fairly simple - wiring, actuator, link rod and clips either end? Drivers door FUD500020 Actuator & switch assembly-central door locking driver's door CWH000010 Clip-linkage FQK500040 Link rod Latch to actuator IPN500250 Clip-linkage Latch to actuator LR016315 WIRING HARNESS FRONT DOOR WITH ELECTRIC WINDOWS - DEFENDER 2007 ON Passenger door FUD500030 Actuator & switch assembly-central door locking passenger’s CWH000010 Clip-linkage FQK500040 Link rod Latch to actuator IPN500250 Clip-linkage Latch to actuator LR016316 WIRING ASSY FRONT DOOR PASSENGER DEFENDER Sorry to ask - Is there anything else I need? I haven't removed the door cards yet - I'm guessing I should already have these holes pre-drilled in the door casing? ![]() I understand that as per the technozen page I'll likely need to get the 10AS modified also as it has reference YWC50066 on it. Many thanks, Cheers, Andy... Edinburgh, Scotland http://24heuer.com |
