Home > Maintenance & Modifications > Callipers Rebuild. Tips fitting piston seal retaining ring?
Page 1 of 3 123>
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
I went to change the brake pads yesterday but on inspection the calliper pistons, all round, are in a bad way and wont sit back in the callipers to allow the new pads to fit. New pistons and seals should arrive tomorrow but I've read it's a real pain getting the new seals in?
I've got got all the callipers on the workbench and all the old cylinders out.
Will it help if I put the cylinders and callipers in the freezer first?
Any other tips?
Thanks in advance. Dan.
Post #525548 20th Apr 2016 5:30pm
ibexman
Buy new calipers your life depends on it Whistle
Post #525549 20th Apr 2016 5:34pm
dorsetsmith
all good practise to repairs and or replace in pairs as one side will brake uneven and will pull to one side Exclamation
http://www.defender2.net/forum/topic45538.html
Post #525552 20th Apr 2016 5:53pm
danridge
The callipers are all serviceable and I am servicing all four corners.
I should have asked, does anyone have any tips for fitting the seals? the metal retaining ring/collar is very easy to bend.
Thanks.
Post #525553 20th Apr 2016 6:01pm
Fatboy Slim
Wales
Fit the seal into the ring first. I've got a bit of plate that I fit over the seal and then use a heel bar to press on top of the plate. Once you've got the knack they go in easy enough. It's one of those things I keep meaning to video as it's easier to show people than explain really
Post #525556 20th Apr 2016 6:18pm
Devon-Rover
Use Genuine Seals and retainers..
Clean the grooves in the caliper out very well so the new items fit.
Use a little red rubber grease or a little bit of brake fluid as a lubricant.
Use genuine seals and retainers
Apply pressure using a flat edge across the retainer and gently work it evenly to get the retainer to pop in.
As above it's easier to demonstrate than describe how to do it. I have rebuilt a few pairs of calipers in my past and haven't killed myself yet. Thumbs Up
Ohh yeah before I forget Use Genuine seals and retainers as they are made to a higher tolerance and fit much easier. Very Happy
Post #525557 20th Apr 2016 6:32pm
Rickydodah
My tried and tested technique after scores of calipers rebuilds is: assemble the dirt seal into the ring, rubber grease should be applied which helps but does make them slippery little bl**ders. Position them loosely into the piston hole and put a small bit of plate over this assembly. Squeeze into position with a "G" clamp, it doesn't need much pressure, if it does then it's likely gone askew. Lubricate the piston with the rubber grease and it should need only finger pressure to push home through the dirt and fluid seals. This technique was shown to me at the Girling factory in the sixties when disc brakes were somewhat unusual and nobody really had any idea how to service them. It worked for me then and I've not found an easier way, if there is I'm happy to learn it. Good luck it's not difficult providing you keep everything clean, it's doesn't have to be diesel room clean but brake components are machined to fairly close tolerances and you don't need much muck to screw it up. Thumbs Up I started with nothing and still have most of it left!
Post #525559 20th Apr 2016 6:42pm
Rickydodah
The use of genuine parts I also follow......not necessarily from a LR dealer but from the calipers maufacturer, e.g. AP Lockheed, Girling etc. I started with nothing and still have most of it left!
Post #525561 20th Apr 2016 6:45pm
dorsetsmith
Use Genuine Seals and retainers.. have had problems in past with parts of repair not fitting
17H8764L - BRAKE CALIPER INTERNAL SEALS RRC you will need there seal if you split them, not included in most rebuild kits Exclamation 6 QTY for both front and rear split rebuilds
Post #525579 20th Apr 2016 7:41pm
danridge
Alas I've already order non-genuine parts but I did order additional as anticipated at least a couple of Censored moments over the 6 pistons. Having read this (much appreciated) advice I fear I may be back ordering genuine parts tomorrow night Very Happy
Thanks for the tips Thumbs Up
Post #525585 20th Apr 2016 7:53pm
Fatboy Slim
Wales
Non genuine will be fine Thumbs Up
Post #525587 20th Apr 2016 8:02pm
danridge
Thanks Smile
Any tips for removing the old seal retainers? Should they just pop out with a small screwdriver?
What Loctite product should be used to secure the caliper 13mm 12 point head bolts?
Post #525683 21st Apr 2016 8:32am
Rickydodah
Old seals and retainers should just pry out. I would replace the caliper bolts as they come pre-coated with thread lock, they're about 60p each. Thumbs Up I started with nothing and still have most of it left!
Post #525698 21st Apr 2016 10:26am
danridge
New bolts ordered thanks Thumbs Up
Post #525722 21st Apr 2016 12:38pm
danridge
Okay so the seal retaining rings are not popping out as I'd hoped. Seem to be corroded in. Any tips?
Post #525739 21st Apr 2016 2:32pm
Page 1 of 3 123>
