Home > Off Topic > Defender2.net on Macbook pro |
Petronius4 Member Since: 07 Oct 2015 Location: Somerset Posts: 94 |
Yep I have the same situation.
As far as I can determine it is down to the difference between iOS and OSX and the way they operate. iOS is a mobile operating system so it has built in capability to keep you logged in (for updates, notifications, etc) whereas OSX has evolved as a desktop operating system and assumes that security is paramount and auto logs you off sites to lower the risk of someone else posing as you on your own device. I know, I can't figure the logic either but thats how they're built so I guess we just have to live with it.....unless..... ------------------------------- 👲🏻 1986 ex-Military 90 NAD 2.5 Soft Top. Sold 🇬🇧 2015 Defender 90 - Ripon Landrover Heritage 006 |
19th Apr 2016 4:36pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
I'm on a macbook pro and rarely need to log in!! My 109 thread
my youtube channel |
19th Apr 2016 4:53pm |
I use an iPhone, iPad, and MacBook. With none of them I have this experience with Defender2.net, all three keep logged in.
However on another forum, I have to log in usually several times a day, very annoying! Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
19th Apr 2016 4:58pm |
Matthias Member Since: 03 Mar 2015 Location: Ruddervoorde Posts: 34 |
i check this forum on a macbook pro and an iMac and safari automatically fills in my username and password.
its very easy, just click on the log in button and you're in. |
19th Apr 2016 5:52pm |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 822 |
Maybe you need to change security preferences on the Mac book Have fun be happy
19th Apr 2016 6:11pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
I regularly get asked to log in on here with both my iPhone and iPad - the inconvenience is highlighted by the fact that it doesn't happen on any of the other sites I visit. I'd put it down as a peculiarity of this forum ...?
19th Apr 2016 6:14pm |
messier104 Member Since: 12 Sep 2015 Location: Berkshire Posts: 30 |
Check that you are not using a "Private Window".
Click, File, New Window, then try again. |
19th Apr 2016 7:39pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
This can be an effect of the forum software. Do you view the forum while mobile (away from the WiFi you use the Macbook on) ?
The cookie that gets set to allow the browser to "remember me" can be linked to IP address and/or browser version at the server end. When it sees a login for the same account using a cookie from a different browser or IP range it can clear the record of other cookies from the server. When your browser "presents" the outdated cookie to the server it's then not recognised. One possible cause of this is using different browser versions, if you're using the latest iOS and an older version of OS X it might be that that is killing off the cookie. One thing to check is your Safari preference, as stated above the browser needs to store a cookie on your Mac to allow you to auto login. Once you have logged in, in Safari go to Safari -> Preferences -> Privacy Tab. Make sure your Cookies and Website Data setting is set to "Allow from websites I visit" or "allow from current website only". You can also click on the small "details..." button below the remove all data button, do a search for defender2 and make sure that it lists an entry there which should say something like Cache, Cookies, Local Storage. http://www.yorkshireoffroadclub.net/ |
19th Apr 2016 9:09pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2497 |
Thanks for all your suggestions. Having looked at all my settings and done a bit of tweeking I am pleased to say - I STILL HAVE THE PROBLEM!
Guess I'll have to live with it but when your used to putting up with the idiosyncrasies of a Defender then it's no bog deal. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
22nd Apr 2016 8:48am |
