Home > Maintenance & Modifications > Alpine window cut out
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
After a bit of advice, and I expect I know the answer.
I'm in the process of cutting alpine windows into my 90 but I have noticed that either end of the window glass is a different shape. The right hand end of both bits of glass are an even shape curve, but when I compare them to the left hand end it looks like a dog has been chewing it.
My assumption is that this is a Land Rover quality control issue in the glass manufacture, and the aperture for the roof light should be the same shape both ends.
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #524992 18th Apr 2016 1:12pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Only one part number for left and right listed although there is both 4mm and 5mm versions Smile
http://www.allbrit.de/UNI.cfm?PAGE=765651&SPRACHE=EN
Did you buy genuine glass or aftermarket? Maybe you need to return the glass
Post #524993 18th Apr 2016 1:23pm
CarMan
I plan to do mine (and the rear quarters) but I see that the MY goes up to 2006 only, though presume they didn't change until the end of production? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #524997 18th Apr 2016 1:39pm
Shutts
The glass is the 4mm version and came off eBay, 2nd hand from a roof that was being scrapped. The make on the glass says 'sicursiv', which is the same as a mates defender that I used to take the position from.
As you can see from the picture below there is a vast difference between the left and right has side profiles, and not sure the gasket will cover it.
The only other option is to cut the hole to match the glass but one end might look a bit odd.
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #525024 18th Apr 2016 3:39pm
CarMan
Sure this doesn't help your issue in any way at all, but it seems the earlier model years had thicker 5mm glass in the rear quarters at least, so maybe also the alpines, compared to later model years which have 4mm glass - or so I hear
Post #525285 19th Apr 2016 2:44pm
VeeTee
Netherlands
Re: Alpine window cut out
I think indeed your answered you own question there. Regardless which shape they will leak anyway Rolling with laughter Wink
Now seriously - I would cut the same (right) aperture and fit with a good grade cauking, e.g. Sikaflex. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #525289 19th Apr 2016 3:02pm
Shutts
Fitted the first window on Tuesday and left the gasket long so it will should compress well and no gaps should appear if it shrinks a bit.
It started to rain tonight so I will see if any water got in tomorrow morning.
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #526088 22nd Apr 2016 10:26pm
