![]() | Home > Puma (Tdci) > Puma 110 MY11 - Leaking |
prob the windscreen seal 2.4 90 XS
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
wasnt this the rear? Mike |
just in case its the same?
mine is in at the moment as the floor panel to the boot doesnt have any sealant where its riveted with dome heads - might be worth a look. Water makes its way in while driving in wet conditions - not a problem while stationary but unless you've bought a model to look at and not drive might be an issue. |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Yes its in the rear. |
I was reversing ![]() 1968 1/32 scale Britains 109 Pick up. |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
Bruce
I found that although the seal was in place the bolts pulling the "canopy" down were not tight enough and you could move the seal around between the two. I tightened the bolts after removing all the rear panels and fitted silicone from inside which incidentally squeezed all the way to the outside demonstrating the size of the air gap. The panels all pull off easily but I also made a tool to get neatly ender the panel pins for the side panels. You just have to buy a few new pins if they break |
Thank you Capelandy.
I have a feeling this is the problem as after a few days of driving it around, i found two bolts (10mm I think) that I dont have a clue where they come from, in the back of the Defender and the rattles had stopped. I will pull the panels to check. Could you show me a picture of the tool. (even if you mail it to me at bjturner5@gmail.com) Thankyou |
10mm thats roof to side pannel i would wager! Loads all around from rear door to B pillar and then across the windscreen Mike |
Thank you all for the replies. I now have a few things to look for. I will feedback to let you know what it was.
Dont forget - take the trim off sit in the back and get someone to spray the car with a hose Mike
Will do. Thanks again MSE.
BTW I was looking at it again this morning with a torch. I noticed from the outside a small join in the rubber about 400mm from the rear. This join is not very good. When I opened up the join, I found that it has not been joined evenly all the way through. I also noticed that the gap in the front of the panel is slightly more than towards the back. (could mean the back is not tight - this could be where the nuts that I found come from) Got to love the Land Rover QC department! I will strip it this weekend and see. Thanks again for all the help. |
I cant go and check to see if its still the same but...the rear window seals and the alpine seals are types that once the glass is in them (and the seal) and both are in the pannel a filler strip is inserted in the middle of the seal to locate it. There is a small gap in that sometimes...it might not be what your on above, infact the puma may have changed it - ive only changed the glass on a 300Tdi defender Mike
Hi All....just a report back.......I found the leak .... I THINK!
![]() After taking all the advice here I removed all the panels in the rear. Was actually easier than I expected. I then found in about the center of the side windows there is a bracket holding the center of tha canopy down. These did not have nuts on both sides (left and right). So I fitted the ones I had found. I then tightened the canopy down a bit more on the 4 corner bolts/nuts..... it still leaked. Sealed everything with sealant and it still leaked...... Then I did what Mse suggested ![]() Another good thing about this exercise is that I have also sealed up all the joints that allowed dust to come in. Thank you for your help. |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Hi guys,
It's going to be trickier for me ![]() Any ideas? |
