Home > Maintenance & Modifications > Headlamp Grills
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Headlamp Grills
Anyone had problems with fitting, if you line them up to the headlight surround then they are not parrallel to the grille !!! and they are genuine ones , or is that the problem...
Post #51373 6th Jan 2011 5:20pm
BigRuss
I found a similar problem when I fitted the kbx grille and head light surrounds to mine.
I think the answer is that no 2 defenders are the same and non are square Thumbs Up Russell
2011MY 110 XS USW Black
Post #51382 6th Jan 2011 6:15pm
Glynparry25
Sounds like your wings aren't straight- they have a habit of slanting. Take back to dealer and explain- they should straighten them up Thumbs Up
Glyn Sheep
Post #51386 6th Jan 2011 6:23pm
mse
Plus you need (when fitting) to line them up to the same points.
I went for the AC cowel - but then mine lined up fine! Mike
Post #51455 6th Jan 2011 9:11pm
rick
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I had that and it drove me crazy for weeks. I decided to line up the headlamp grills with the centre grille and now I also have an ARB bull bar - problem expensively solved!
Cheers,
Rick. 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
2015 Discovery Sport
Post #52520 12th Jan 2011 10:27am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I fitted mine OK!
Vertically alingned with the AC grille, horizontally aligned it with the headlamp plastic light surrounds ... 1mm more or less ... marked the spots ... on the other side just marked the spots with same distance!
But could be the headlight surround ... on my Td5 the one on the right was not fitted correctly, it didn't align with that horizontal gap/line on the wing panel above the lights Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #52523 12th Jan 2011 11:14am
