Home > Maintenance & Modifications > Removing the steering wheel
Loz2286
I want to remove my steering wheel (1999MY Td5 CSW - 36 spline wheel) to fit an after market wheel and to improve access to the column switch gear to do some work. I've tried the wiggle-waggle method and using a small puller and no luck. It just won't budge. Is there a knack to it? Am I missing something?
Thanks. 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #523839 14th Apr 2016 10:57am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
They often do get a bit stuck on the splines, try loosening the nut and undo it until the threaded end of the column is just below the outer end of the nut and then give it a tap with a hammer while pulling upwards on the wheel.
Otherwise a puller is in order.
Post #523841 14th Apr 2016 11:04am
Buz
United Kingdom 1987 Defender 90 200 Tdi HT Barolo Black
I sprayed it with PlusGas, went and had a coffee, tap with a hammer and off she came.....
Post #523842 14th Apr 2016 11:12am
Chocolate
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Did mine recently, used a puller, that wouldn't do it by its self.
Sprayed plus gas to see I that helped.
Rocked it side to side while pulling (Leaving nut on!)
Nope no joy.
Ended up with a club hammer knocking under the wheel with the puller on.
Eventually it popped off. 110XS CSW TD5.
Post #523843 14th Apr 2016 11:14am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
All this hammering, make sure you leave a few threads on the nut or you could recive a steering wheel to the face. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #523855 14th Apr 2016 12:22pm
jimbob7
Hands at 3 and 9 o'clock and waggle the steering wheel comes straight off,trying to pull it straight off doesn't work. Pov.spec,ftw. 2006, 110,TD5.
Post #523957 14th Apr 2016 6:27pm
Loz2286
Tried all the above - still no luck.
So I put the puller back on and tightened it up and left it overnight. The steering wheel was on my seat in the morning.
Thumbs Up 1999 Td5 110 CSW
Post #524191 15th Apr 2016 12:46pm
YOLO110
Australia
Did you sit on it! Very Happy YOLO... You Only Live Once...
Post #524210 15th Apr 2016 1:31pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Thumbs Up
Rolling with laughter Rolling with laughter Rolling with laughter My confidence has been writing cheques that my abilities can't cash for years.
Post #524307 15th Apr 2016 8:24pm
Peter D
Well, in anticipation of the new after market steering wheel, I'm struggling to remove the original LR steering wheel on my 2013HT. I've tried the above tips but without success so it seems that I now need a puller.
Could someone recommend, or provide a link, to a puller that would fit. There seems to be a wide variety of types available and I'm still not clear what this would attach onto to provide the leverage required.
Any help would be gratefully received. Bow down
Here is a photo of the said item.
Regards
Post #524707 17th Apr 2016 11:40am
sat13
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Peter D
It looks like you have no tapped holes in the wheel centre boss. Mine was the same when I came to remove my wheel.
I couldn�t fit a normal puller, so had to drill and tap two holes in the boss so I could use a puller. I think Landrover in their wisdom decided to stop putting the tapped holes in the wheels and save some money.
I have seen a few without the tapped holes in. The wheel can be very hard to remove no matter how much banging and pulling some refuse to give. And the only way is to use a puller. It�s the taper on the wheel and steering column that makes it so tight, a bit like a taper shank drill, after it�s been off once subsequent times don�t seem as tight.
See the pics for ideas on what to do.
Regards.
Post #524769 17th Apr 2016 4:41pm
Peter D
Thank you, the lack of holes on my steering wheel boss explains everything now. I really appreciate your detailed reply and can now see how a puller would work once I've drilled and tapped a pair of holes.
Regards
Post #524778 17th Apr 2016 5:07pm
HardCharger
Hi Peter D,
After you remove the center nut, it may require you to give the steering wheel a little persuasion to get it off. Had mine off for a few times to do this and that and never needed a puller.
I hope this helps.
Post #524900 18th Apr 2016 2:01am
jimbob7
Regards
Remove the nut first in the picture,then waggle the steering wheel,simples Rolling with laughter !! Pov.spec,ftw. 2006, 110,TD5.
Post #525015 18th Apr 2016 3:15pm
Remember also when you refit the wheel not to overtighten the nut. I always use a little anit-seize compound (copper slip or similar) on the splines and taper before refitting. It makes subsequent removal so much easier.
Post #525053 18th Apr 2016 5:12pm
