Home > My Defender > My next Project 90 Hardtop to soft top
Page 4 of 4 <1234
L110CDL
Is it the bearing ? Clayton.
Keeper.
Post #524617 16th Apr 2016 10:11pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Just a few rollers missing there Shocked 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #524618 16th Apr 2016 10:14pm
jst
front off side. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #524662 17th Apr 2016 8:59am
jst
a week to spare and this weekend saw her all done, less one brake pipe to still sort! really pleased with it.
Have put some of the Goodwinch green bowrope on it to try that out. Will see how we go! not that there should be any winching at the BigOutdoors. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #526613 25th Apr 2016 1:25pm
Quite a tranformation, good work! Thumbs Up
Post #526645 25th Apr 2016 3:57pm
jst
Well, shes going realyl strong, very impressed so far, no hood leaks, in fact no leaks at all! drives well on std engine tune with those tyres evening getting 29/30mpg regularly!
Just fitted Gwyn Lewis Mud deflectors that i picked up at the last Big Outdoors event, real easy to fit and have to help stop the corrosion!
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #563927 14th Sep 2016 7:36pm
jst wrote:
Cut down the rear door and used some ali u channel on the top of finish it off.
Hi James,
I've just found this thread from your for sale ad and wondered if you could give a bit more detail about cutting down the door, as I'd like to do the same to mine. For example, did you have to construct a frame behind the top edge or did your ali channel give it the strength it needed? Did you cut the skin down to the same length as the frame or leave it longer and fold it over? Do you have any 'work in progress pics', by any chance?
Thanks in advance. Darren
Post #565765 22nd Sep 2016 11:59am
jst
i used a 2007 one piece door and just it just above the handle opening having first made sure i could get some Ali channel that would fit over the front and back of it. i cut front and back same height _ jigsaw. and made a ali chq plate back for it that came to the channel. i fitted the stronger later wheel support brace inside the frame. no other fabrication or strengthening was done.
you can buy them as half doors i see, but i didnt have the time to wait once i realised that!
an earlier two piece door would need further work to make it strong enough. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #566077 23rd Sep 2016 3:27pm
Thanks James. I don't want to hang a wheel off it, so ultimate strength isn't a big consideration.
I have seen the kits but at over £300 they seem like a lot of money for not a lot of door! Still, I'll see how mine pans out when I'm ready to do it. Darren
Post #566083 23rd Sep 2016 4:01pm
Page 4 of 4 <1234
