Home > Maintenance & Modifications > Battery life
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Battery life
Hi, owing to the low usage that my 90 gets I'm increasingly finding the battery is no able to start it up. I have had the battery tested and it is good it just doesn't really get used enough to charge itself and is then left for weeks at a time running the trackstar system. The car has always been a pig to start to the point of everything that could be improved has been so I think it is about as good as it will ever be. What I have been looking into is a dual battery split charge system with one only doing the starting and the other the day to day running of the car kinda like for a winch but not so heavy duty. I can't justify spending more than the cost of a half decent boost pack as otherwise I will get one of those and keep it topped up in the jimny? What are the options for off the shelf solutions? Rhubarb and custard let fly with their secret weapon.
Post #523803 14th Apr 2016 7:51am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Can you park it somewhere where there is access to a domestic mains socket? If you can then just get one of THESE -www.tayna.co.uk/Numax-Car-Battery-Charger-10A-P6130.html and hard wire the fixed lead conection so you can plug it in whenever the vehicle is to be left for more than a couple of days. Your vehicle will always have a tip top charged battery and the battery will thank you by giving a far longer service life from not being continually discharged and then crash charged.
Post #523811 14th Apr 2016 8:42am
dorsetsmith
or solar charger no need for mains power
http://www.maplin.co.uk/p/solar-powered-12...GwodLqQMrg
Post #523814 14th Apr 2016 8:51am
lambert.the.farmer
No mains power unfortunately but it is under an open fronted shed so I will look more at solar. Cheers. Rhubarb and custard let fly with their secret weapon.
Post #523816 14th Apr 2016 8:58am
I Like Old Skool
There is another way. Disconnect the battery when the vehicle is parked up, although I guess this will also disable the tracker until the power is restored?
Post #523932 14th Apr 2016 5:06pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
I use a 10W solar panel as my 90 sometimes doesn't get run for a week at a time.
The start up is always crisp. Very Happy
Post #523997 14th Apr 2016 8:51pm
lambert.the.farmer
Having discovered that my multimeter is on the fritz and refuses to read amps I have got another and will test the draw with the car switched off and determin the amount of milliamp I need to feed it, no point giving it 300 if it only needs 45 as it were. Are the maplins solar chargers as good as any or is there no real difference with a cheap one off amazon? Rhubarb and custard let fly with their secret weapon.
Post #524379 16th Apr 2016 4:37am
cobra_mark
All my solar panels have come from eBay the most recent is a 20w panel for my Volvo as the electric draw on modern cars is more than the 90 Defender. I wouldn't go much higher otherwise you need greater protection for the vehicle.
Post #524383 16th Apr 2016 6:41am
Cupboard
I got my last solar panel from http://www.sunstore.co.uk/ but that was a relatively big one.
If you have somewhere like on the roof of your shed to put it then you could have a permanent mount panel with a quick disconnect or use the towing electrics.
Multimeters, almost all of mine are Tenma branded from http://cpc.farnell.com/ - Tenma is the Farnell own brand. It ranges from basic to good but even the cheapest work fine. I'd avoid the non-Tenma branded ones though, they can be a bit pants. A lot of meters come out of the same factory, I've had Uni-T meters the same as RS meters the same as Farnell meters.
I've also got a DC clamp ammeter which is good for higher currents like checking the charging circuit is working properly. I've also got an autoranging one which is extremely handy for automotive stuff as you can put it on the 10A range connections but will still range down to milliamp measuring. It means you don't blow the fuse and kill it if you accidentally open a door.
Post #524427 16th Apr 2016 10:43am
lambert.the.farmer
Rubbed the new meter over it and it appears to be drawing between 25 and 30 milliamp which is plausible split between the trackstar and the clock. So I think the 2.4 watt one that gives a maximum of 137mA should cope? Rhubarb and custard let fly with their secret weapon.
Post #524477 16th Apr 2016 2:17pm
Cupboard
Sort of...
In the winter bargain for 5-10% of rated output by the time you've got nights. I'd be wanting a 5W panel at least.
Post #524482 16th Apr 2016 2:43pm
lambert.the.farmer
Ok thanks. Rhubarb and custard let fly with their secret weapon.
Post #524562 16th Apr 2016 7:47pm
lambert.the.farmer
Ok I got myself a 10w one by friendly green giant from the ripon 4x4 spares day yesterday. Seems to work well on the bench, have wired it to a plug and rings so I can demount it easily just need to make up a bracket for the dashboard and it's in business. Rhubarb and custard let fly with their secret weapon.
Post #524904 18th Apr 2016 5:44am
williamthedog
Been watching this thread with interest.
I dont use the defender that much in the week this time of year.
Looking at a 20w one on ebay c/w usb socket as well.
Would this be ok or is it a bit too much ?
Post #524906 18th Apr 2016 6:02am
lambert.the.farmer
The guy who I got mine from suggested that 10w would be good as much bigger would need a regulator to not cook the battery. Rhubarb and custard let fly with their secret weapon.
Post #524909 18th Apr 2016 6:12am
