Home > Maintenance & Modifications > Optimill door handles
Likeomg
Has anybody else fitted these yet?
got a good deal on them via urban truck, my current plastic drivers side handle had come loose, the threaded part had come unbonded from the plastic so i needed a new handle anyway..
substantial bits of metal to begin with
asked urban about fitting, which they said i had to dismantle the whole door so i had a little look inside.. at first its a complete mess, i fully dynamated my doors so i had to contend with this too
i for some reason didn't take any photos but the way i went about it without taking it all apart was to use my snap on pick set to disable the key lock piece, remove that, theres a little slip pin which connects the actual lock to the actuator etc, i managed to remove that with the pick set, the rod slides off and the 2 (well 1 in my case) screws that hold the handle on are next. It's all held together with slip on joints which are actually a welcome relief when working on defenders..
i mounted the new handle first, don't use the supplied bolts as they are too small imo (both head and length) then using the pick set replace the slip pin... passengers side is even easier as it doesn't have the key lock to contend with..
was told about 2 hours / door, first door took about a hour; second door 20 minutes max..
only problem now is i dont think i like the look of them? Shocked and i don't like the way they feel in my hand when opening from certain angles there very sharp on the thumb
Post #524344 15th Apr 2016 10:28pm
Likeomg
oops
Post #524345 15th Apr 2016 10:30pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
First time I've seen these, and first impression is they look ok, but can see how they could feel uncomfortable in the hand. But it's only for a second and has got to be more robust than the plastic originals.
I suppose the clincher is going to be the cost. What's the price uplift over a standard handle? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #524347 15th Apr 2016 10:37pm
mick
I see what you mean the ones on the website look different to yours as well Neutral
Post #524349 15th Apr 2016 10:40pm
mk1collector
Do they come with seals/gaskets for in between the handle and door like the original handle? Ray
My build thread
Post #524352 15th Apr 2016 10:45pm
Likeomg
being billet aluminium they were never going to be cheap...
then again a standard pair of door handles will run you about £120, these however, at full rrp you might get 2 pints out of £300...
i didn't get much discount either, my car does have pretty much every upgrade available so stuff like this is about all that i can do to it..
@Mk1 yeah, they have new gaskets.
Post #524353 15th Apr 2016 10:45pm
Rosco
A standard pair is how much? Shocked Shocked I just spat beer out at that!
Out of billet £300 for all four doors doesn't seem that unreasonable 2007 - Stornoway Grey 90 XS SW - Gone
Post #524357 15th Apr 2016 11:01pm
Likeomg
i have a 90 Laughing
so thats 300 for 2 doors..
the £55 for a standard one is a genuine price (there going for sub £10 for a britpart)
Post #524358 15th Apr 2016 11:02pm
Rosco
Ok £600 for a 110 is a little rich for me! 2007 - Stornoway Grey 90 XS SW - Gone
Post #524360 15th Apr 2016 11:05pm
N16kct
United Kingdom 2010 Defender 110 Puma 2.4 USW Corris Grey
What put me off is the oval button. I can't believe no one has manufactured ones that look like the standard ones but from Ali?
Apart from overfinch and the autobiography ones made from unobtanium.
Post #524455 16th Apr 2016 12:40pm
Likeomg
There so far the only purchase I'm a bit sceptical of,
The way your thumb gets caught when you open the door is a bad design imo
Post #524457 16th Apr 2016 12:42pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Sorry but it looks as if someone has bent some flat bar into that shape. Not something I would want on mine. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #524498 16th Apr 2016 3:34pm
mick
That's what I thought for the £ disappointing
Post #524585 16th Apr 2016 8:56pm
L110CDL
Hi likeomg as you and no one else likes your door handles, i would take them of your hands for a sensable price, if they fit 96 defender doors Thumbs Up Clayton.
Keeper.
Post #524631 16th Apr 2016 11:12pm
Likeomg
i guess they would fit, however no ill just learn to love them... ill maybe give it a wash tomorrow and upload some proper photos.
Post #524644 17th Apr 2016 12:37am
