![]() | Home > Maintenance & Modifications > Roll cage fitted |
| AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116
Thanks mate. 2011 Defender 90 SW
2006 Discovery 3 HSE |
| grizz Member Since: 31 Aug 2014 Location: cheshire Posts: 208
It's easy to replace a wing , it wouldn't take much longer with a sd cage than a normal wing .
The front wing outer has to be removed and modified to have the cage fitted . |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11083
Thanks Camelman, imho i think the tyres you got on now are perfect
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2528
First dibs on the KO2 if you go 37"
was thinking of putting 37" maxxis trepadors on my DPCU 2015 Discovery 4.5 Black pack Firenze red XS |
Click image to enlarge 37" treps fitted with +50 MM. wider arches |
Any mods suspension wise?
Im planning to put +2 OME springs with +5.5" nitro charger shocks onto my 110 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
Just +2" ome springs and +5" shocks with caster adjusted arms , it needs a little more lift so I'm fitting Spring spacers
