Home > Technical > Oil leak handbrake drum!!!
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Oil being thrown out of handbrake drum! Handbrake slipping!!
Will she get me to the UK or should I get it fixed??
I'm in Northern France on my way home?
I guess no oil in transfer box is not good? Winter's here, thanks goodness!
Post #521886 7th Apr 2016 3:17pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
I would just top the oil level up if it's a big leak and sorted it once home.
Hope there's not to many hill starts on the way...
Post #521890 7th Apr 2016 3:44pm
Chamois
Might have to chock it on the ferry tomorrow morning then!!
Thanks Winter's here, thanks goodness!
Post #521924 7th Apr 2016 5:12pm
Happyoldgit
Output oil seal and a fairly simple job to replace. Steve.
http://forums.lr4x4.com
Post #522155 8th Apr 2016 11:05am
Chamois
Made it to the UK, gonna fix the oil seal this week! Winter's here, thanks goodness!
Post #522518 9th Apr 2016 5:44pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I recommend oem parts, and a tin of brake cleaner to ensure the drum and shoes are cleaned, if there is excessive oil on the shoes bin and replace, not worth the risk Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #522619 9th Apr 2016 10:43pm
Chamois
Replaced break shoes and output shaft seal today.
Output shaft nut was loose, not a good thing.
Probably why it was leaking.
Has stopped a bit of vibration on acceleration too! Winter's here, thanks goodness!
Post #523766 13th Apr 2016 9:32pm
mick
Did you use the sealer ( like thread lock ) on the seal I didn't and it didn't last long
Post #524062 14th Apr 2016 10:45pm
Chamois
No, but used 'Bearmach' parts and went for a new flange kit so hoping that would be the go.
Also went 80 90 on the Transfer Box oil rather than 75 90 what difference that will make time will tell. Winter's here, thanks goodness!
Post #524120 15th Apr 2016 8:38am
mick
Fingers crossed
Post #524313 15th Apr 2016 8:41pm
