![]() | Home > Maintenance & Modifications > Hazard light staying on |
![]() Click image to enlarge water in hazard relay under dash or wiring short out |
Had this happen to me when speeding on a heavily corrugated road in a Discovery. Turned out to be a safety measure in the event of an accident. Had to remove the glove box and reset something - think it was a relay.
Defender may have similar? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2748 ![]() ![]() |
There's some kind of crash switch under the bonnet on a Td5 I think, which can be reset after an impact.
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1636 ![]() ![]() ![]() |
Hi thank you all for the replies one thing he didn't mention was the central locking wasn't working either,In the last hour I've checked the relay that was fine although strangely when I pressed the hazard warning switch on,the relay was ticking and when I switched them off the relay stopped clicking but there's a green box behind the dash and that was ticking with the lights flashing
This is from the MY12 Workshop manual but may be of some help:
"The anti-theft system module also incorporates an internal inertia switch. In the event of an impact of sufficient severity to trigger the inertia switch when the ignition switch is in position II, the anti-theft system module will unlock all doors and operate the hazard flashers. The anti-theft system module will remain in this mode of operation for 2 minutes. To deactivate the hazard flashers and restore the anti-theft system module to its normal mode of operation, the ignition switch should be turned to position 0 and back to position II after the 2 minute period has expired." |
hi supacat many thanks for that its obviously what happened as the pheasant hit the bulkhead and bottom drivers side of the windscreen,he runs a shoot so I'm guessing the pheasant was getting revenge
