Home > Td5 > Basic TD5 toolkit
bluebottle
Basic TD5 toolkit
Hi all,
Just wondering about putting together a little tool roll for my truck, what should I have in it?
I'm thinking a handful of spanners for the most common sized nuts, pliers, wire and strippers, fuses? Spare bulbs obviously.
Bear in mind my automotive mechanical skills are very basic I don't envisage removing a prop shaft by the roadside or anything, but more for things like the rear mudguard bracket deciding to shear off its mounting (as happened to me at New Year on a trip laning on Salisbury plain... Rolling Eyes )
Post #521184 5th Apr 2016 4:13pm
Loz2286
Selection of open ended and ring spanners, two of each, 8mm, 10mm, 13mm, 15mm.
Pointed nose pliers
Multi-head screwdriver
Roll of duct tape
Roll of wire
Selection of zip ties
Selection of bulbs and fuses
Can of WD40
Mobile phone
AA membership card for everything else...... 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #521199 5th Apr 2016 5:01pm
dorsetsmith
small multimeter as-well about things
Post #521223 5th Apr 2016 6:09pm
srod
2.5lb lump hammer comes in handy more often than I expected.
Post #521273 5th Apr 2016 8:04pm
roel
The problem is that you always need something that you don't carry. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #521343 5th Apr 2016 10:01pm
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
The first winter back in a small cloudy island near the North Pole after 25 years away .... most used has been torches and plug in lights. It seems to be dark all the time. ...and boiled sweets for traffic jams.
Then screwdrivers, pliers and 3 in 1 oil, - for various friends and family who assume if you have a Land Rover you can fix their outside tap / light fitting / door hinge ...
Least used, incl on Salisbury plain, has been wheel changing gear. But it may happen and they are heavy. I just bought an extension bar and socket - plus I have bottle jack and LR supplied screw jack. Practise at home. At least 3 times. With the various torches and lights. .... Whistle Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #522203 8th Apr 2016 12:42pm
miker
Headtorch! With decent batteries in it. The lithium AA's are ideal.
Removing a prop is as simple as removing 8 nuts, so may as well chuck a 9/16" ring spanner in.
Decent bar for the wheels, jack that actually works. Make sure none of your wheel nuts have swollen because they have stupid stainless caps on them! (Half of mine need an 1"1/8 socket to remove, 27mm doesn't fit!!)
Post #522648 10th Apr 2016 2:00am
bluebottle
Great suggestions so far guys - I can see the remarks of experience on here, exactly why I asked!
Post #523448 12th Apr 2016 7:40pm
bluebottle
Right - I managed to pick up some spanners and a nice screwdriver set (with a multi-angle head, 45 & 90 degree) from Screwfix. Got some cable ties and a roll of gaffer in there too. Plus a tow rope and litre of oil and I reckon that's good for now.
Post #537544 4th Jun 2016 7:27pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Litre of coolant??
Post #537561 4th Jun 2016 8:34pm
bluebottle
So far (and I realise how massively I'm tempting fate here Rolling Eyes ) my beast has been absolutely rock-steady for temperature, even at 70mph on the motorway for 4 hours...
I might see how much space I have left under the front seats and squeeze some in.
Post #537630 5th Jun 2016 9:01am
TOP5N
This is handy, as i have too been thinking about the same thing
Post #538657 8th Jun 2016 9:00pm
