Home > Technical > Landrover Defender Td5 ignition barrel removal
submarinealan
Looking for advice . what is the easiest way of removing the ignition barrel on a landrover Defender T5.
Thanks Bow down
Post #523084 11th Apr 2016 4:27pm
Fatboy Slim
Wales
Take the dash binnacle out. Disconnect the connections on the back of the barrel. Take the steering column shroud off. Centre pop the heads of the shear bolts and either drill the heads clean off or drill and eazi-out the bolts.
Post #523095 11th Apr 2016 4:59pm
submarinealan
Cheers will give it a go
Post #523107 11th Apr 2016 5:27pm
