![]() | Home > Td5 > Td5 Anti-roll bars on 110 CSW - advice please |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
It's generally considered that the rear one has more effect than the front. I'm not sure exactly what the reason is for this. All the uprated ones are for the rear, not the front. That said, LR felt in necessary to fit one front and back, so there must be a reason for that. Perhaps fit a standard one at the back first and then if it's still rolling in the corners, add the front too. I know there are some people who just run an uprated ARB on the rear, so that would be another option. Standard take-offs a cheaper option though. 2005 Td5 | 90 Station Wagon | Tonga Green
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
I fitted one to the rear on my 110 DCPU specifically to reduce body roll when I had my rack and roof tent on. Did the job perfectly and I didn't feel the need to put one on the front.
I've got the anti roll bar and fittings for sale if you're interested. 2015 90 XS CSW TDCi - Beautiful 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
I fitted front and rear ones to mine and it made a great difference to body roll. For the cost of take off ones I'd fit both to avoid any more sea sickness
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
thanks for replies. I'm going to fit rear one first i think and see how it feels before fitting the front. either way should feel tighter drive.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3507 ![]() ![]() |
Don't just fit one anti roll bar, there's a chance it will make the handling unpredictable.
Britpart do a full kit for around £200 with front/rear anti roll bars and all the fixings. I fitted the kit to my 2005 110 CSW and it made a big improvement to the on-road handling. The kit is easy to fit and you don't even need to jack up the vehicle, although it's easier if you can drive it on to some ramps. |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1791 ![]() ![]() ![]() |
Most small hatchbacks only have the front, a common handling mod is to add a Rear.
THe rough effect is that a front ARB will reduce roll at the front but increase the tendency to understeer. Adding a Rear ARB will flatten the rear in a bend. This should reduce the tendency to understeer. Too stiff a RARB will cause the car to tend towards oversteer. |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
This article would be worth a read.
http://www.extreme4x4.co.uk/acatalog/LRM_i...%20Kit.pdf |
