Home > Puma (Tdci) > Pumas not a good choice for a tall person
Rogue_0
Wales
Hi
New to the forum, looking for advice. I have decided to buy a 110 double cab pick up and I am interested in the puma type. However I have heard that they can be a bit tight on people over 6ft.
Anyone got experience?
Post #522529 9th Apr 2016 6:18pm
grafty99
Depends on what you are used to and what you're willing to put up with.
I'm 6'4" and both my puma 110 sw and td5 90 hard top I have found to be easily all day comfortable. However other than my motorbike a defender is my daily transport so it's all I'm used to.
Yes my left knee was near the dash in the puma and the door pull handle is in your right thigh but not to the point of being a pain.
Best advice is take one on an extended test drive where you can drive down a carriageway at a steady speed and get relaxed into your driving position Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #522536 9th Apr 2016 6:40pm
grafty99
Also, welcome to the forum Very Happy 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #522538 9th Apr 2016 6:41pm
Roy5695
I'm 6ft2 and fit fine, depends what you want your seating position to be like! The only thing i have done is fit a smaller steering wheel so there is room between the tops of your legs and the bottom of the wheel!
Seat risers are another option but could limit vision if you have a tall upper body.
Then there is also the more sportier seats such as the Recaros and the like which alter the seating angle (bum a bit further down) so slightly increasing leg room and comfort.
I personally am happy with just the smaller wheel and standard XS seats. I've travelled over 1000miles in a weekend with this set up and been perfectly comfortable and not achy or having to get out to stretch my legs.
Post #522540 9th Apr 2016 6:44pm
Rogue_0
Wales
Thanks.
Problem with the test drive option I would have to travel an age to fine one.....
More than used to travelling with legs rubbing on handles etc., and tend to get used to it pretty quickly. Like the spec of the Puma, perhaps not the mpg, so will have to find closest best choice and travel to it.
Worth a gamble I reckon.
Post #522542 9th Apr 2016 6:47pm
Roy5695
Im sure theres plenty of people in Wales with a Puma especially on this forum, somebody might let you have a go.
Post #522544 9th Apr 2016 6:56pm
Rogue_0
Wales
Good thought.
Post #522550 9th Apr 2016 7:08pm
Rogue_0
Wales
Post made, and fingers crossed.
Post #522553 9th Apr 2016 7:14pm
Alien
Australia
If you like the Puma, and who wouldn't but still find the seat too close to the dash there is an option.
There are number of manufactured who do seat rail modification kits.
http://www.mudstuff.co.uk/mud-seat-rails.htm
http://www.expeditioncentre.com.au/online-...sions.html Cheers,
Kyle.
Post #522637 9th Apr 2016 11:52pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I'm 6'6'' and 'manage' to fit, with the help of Mudstuff seat rails mentioned above.
I took the supplied washers off the rails to lower them as much as possible, otherwise view out of side window was a problem.
It's my daily drive, toured Europe in it etc., I find my back is more comfortable in the upright Defender than in normal cars, but legs are still a bit tight, but you just get used to it and adapt/contort(!).
I have just purchased a smaller wheel (Startech) which I'm excitedly waiting to fit - hoping that will help the legs a little.
I'm sure a modern Discovery would be vastly more comfortable, but... meh.
Post #522640 10th Apr 2016 12:07am
Edzi
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Alaska White
As already mentioned, seat rails and a smaller steering wheel will help.
Also, get the Nakatanenga leather door handles which take up much less space.
Post #522641 10th Apr 2016 12:09am
AlanH
Australia
I've had 3 Deafener 110s, a Td5, 300Tdi and now a Puma and found only the Puma to be a bit short for my legs at 185cm (6' 1"). I bought some extension rails from someone here in Oz, Mulgo I think, and fitted them on a lazy day during a trip to South Oz.
Amazing how much extra room they give and I really haven't noticed restricted vision from sitting too high. I bet the rail extenders from others will help you settle in OK.
AlanH.
PS. Strangely I also find the seats aren't as comfortable as previous models and a few other things are different as well........ Laughing
Post #522671 10th Apr 2016 9:06am
shipbadger
United Kingdom 2011 Defender 110 Puma 2.4 HCPU Galway Green
I'm 6', but long in the leg and arm. Having recently swapped my Series 2a which had been modified to give more leg and arm room the HCPU seemed a rather 'snug' fit. Some of these things may not be required for a SW/DCPU where the seat can be reclined more or rails fitted. To obtain more elbow and other room here is the list of things I did. Remove the Puma seats, their height causes your shoulders to be pushed forward. Replace with pre-2007 seats. Chuck away the headrests as they are too low to be of use and fit a decent set of seat covers. Fit an Optimill steering wheel boss and a smaller steering wheel (I could not afford a posh one so it's a Mountney). Look for a wheel that is not heavily dished otherwise the advantage of the thin Optimill boss is lost. Be warned the new wheel may partly obscure the dashboard so be aware of this. If appearance is not an issue remove any carpet or matting from the drivers footwell. I did manage nearly 400 miles in a day with the original set up but three months later I did the same journey with the alterations and know which is preferable Smile. There is no single thing that improves matters but a number of incremental changes. Finally if elbow room is a real problem one of the original 110 or military doors with sliding windows gives a little more space.
Tony Comber
Post #522682 10th Apr 2016 9:42am
Cupboard
I find my Puma hardtop a lot better than the farm's TD5 HCPU, with the TD5 I keep bashing my knee on the steering wheel when using the clutch which I don't even come close to in the Puma.
Post #522769 10th Apr 2016 4:10pm
mick
Don't find it a problem
Post #522913 10th Apr 2016 10:47pm
