Home > In Car Electronics > Loud buzzing from front lights.
Ecosse1
2014 Defender 90 Puma 2.2 HT Corris Grey
I've just parked up and with the engine off but the side lights on there is a loud buzzing coming from the passenger side. The side lights and headlights are working, but the noise is concerning. What could be causing this and how should I fix it?
Thanks in advance.
Post #522359 8th Apr 2016 9:51pm
7heaven
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
There's not much in that corner other than lights, horn and BBUS (if fitted), washer bottle. Oh, and the headlight adjust motor . Check your headlight level switch on the dash is at '0' - maybe the adjust motor is running? 2020 110 D200 Base - Pangea with satin paint protection
2015 90 XS Station Wagon (sold)
2010 110 XS Station Wagon (stolen)
Post #522383 9th Apr 2016 6:56am
Ecosse1
It's definitely the side lights buzzing without the key in the ignition, if they've been on for any length of time. No buzzing first thing in the morning. Maybe waters getting in and causing a short circuit.
Post #522700 10th Apr 2016 9:23am
Roy5695
Have you checked for for bee's or wasp nests?
Does the buzzing stop with all lights off?
Post #522702 10th Apr 2016 9:30am
Ecosse1
Looking online, other vehicles have had a problem with the headlight adjustor motor so I'll investigate that further. It seems very like the clicking/buzzing noise others have described.
Post #522739 10th Apr 2016 12:15pm
Ecosse1
Adjustor motor it is. No buzzing when the light beam is set at position 2 or 3. I'll see what Landrover say tomorrow.
Post #522820 10th Apr 2016 5:14pm
meeerrrk
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
mine does this, did you ever get to the bottom of it? My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #606527 3rd Mar 2017 7:36pm
Ecosse1
Yes. It's the adjustor motor. Try each setting on the dash, you might lose the buzzing/clicking; if not you might need the actual motor replaced. Have you changed or removed the headlights at all?
Post #606627 4th Mar 2017 11:55am
meeerrrk
Thanks. It was the motor. I took the headlight out and fiddled with the motor and it stopped buzzing.
I put the headlight back in and it's now fine.
The car has been away for two days having a full closure alarm and immobiliser system fitted so I wonder if they took the headlights out.
Thanks for your help Smile My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #606652 4th Mar 2017 2:35pm
ericvv
Maybe worth put the truck in front of a wall or so, and see if both motors really do their job, meaning lowering and raising the lights step by step same level left and right. I had some problems with one headlight motor too, had it replaced several times, but it never worked properly. In the end it appeared that the real problem was with a cheap plastic piece to which the little motor connects, which was broken. This part is STC4029. More details in below thread.
Eric
http://www.defender2.net/forum/topic42384....or+plastic You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #606654 4th Mar 2017 2:49pm
meeerrrk
That's interesting, and a sensible idea, I'll do that thank you. My 90 Project : http://www.defender2.net/forum/topic52774.html
Post #606666 4th Mar 2017 3:42pm
