Home > Td5 > Weird starting and cutting out issue
excossack
This morning car started ok. Drove to work and left in the carpark from 8am till 5pm.
Got back in the car to come home, started as normal.
A few seconds idling and then cut out. Tried to restart and no - just a long crank with some smoke out the exhaust (grey).
Tried again this time cranking and pumping the throttle pedal and then brummm starred fine. Drove home fine with no lack of power.
Fuel gauge showed just under 1/4 just as it was when I left home.
Filled up with fuel started fine and ran fine.
Ordered a new fuel filter just in case. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #512600 9th Mar 2016 9:16pm
excossack
This morning car started fine. Hopefully it just a blip 1999 Defender TD5 110
Regards
John M0VAZ
Post #512708 10th Mar 2016 8:59am
excossack
The issue happened again last night after leaving work. Started fine then cut out and took an age to start.
This morning it started fine, fuel level again not far off 1/4 tank - same as last night
The issue has only appeared after having the fuel tank removed so the x-member could be replaced. (Could just be bad timing I guess?)
Any thoughts ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #522223 8th Apr 2016 1:30pm
miker
Could be some airlocks kicking around in the system. Or the pipe union onto the tank was damaged/not refitted correctly so you're getting air and fuel.
Post #522224 8th Apr 2016 1:33pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Have you checked the injector loom for oil ingress?
Just seen the tank was removed, as said above check unions for tightness, also some sediment could of been dislodged and this could be restricting the fuel pickup pipe. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #522225 8th Apr 2016 1:33pm
miker
Try priming/purging it. Ignition to pos2, pump gas pedal 5+ times quickly. Engine management light will flash and fuel pump will makes lots of funny noises.
Post #522226 8th Apr 2016 1:34pm
excossack
Mmm good thought but the issue only appears to happen when I get to around 1/4 tank.
Will have a look and see if I can see any leaks - which I guess I would get if the pipe was damaged/not fitted correctly? 1999 Defender TD5 110
Regards
John M0VAZ
Post #522227 8th Apr 2016 1:35pm
excossack
No I have not checked recently but worth a check 1999 Defender TD5 110
Regards
John M0VAZ
Post #522228 8th Apr 2016 1:36pm
excossack
Thanks will give it a go. Normally after replacing a filter I would refit the filter and turn ignition to pos2 and leave it whirling away until the pump stops. 1999 Defender TD5 110
Regards
John M0VAZ
Post #522229 8th Apr 2016 1:37pm
Mash
If only around half a tank I would say it's somthing inside the tank restricting the pickup pipe. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #522230 8th Apr 2016 1:37pm
excossack
More like 1/4 of a tank. From what I saw the fuel pump was not removed - just the pipes. 1999 Defender TD5 110
Regards
John M0VAZ
Post #522231 8th Apr 2016 1:38pm
Mash
Sorry ment 1/4, the tank might have some crap in it that floats around happily until it gets to 1/4 at that point it is drawn to the pickup pipe and restricts flow. I have found everything from rag/wood to plastic bags and empty bottles in fuel tanks on various vehicles over the years. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #522233 8th Apr 2016 1:41pm
mk1collector
Check if the fuel filter is tight. I got a 1/4 of a turn out of mine this winter. Ray
My build thread
Post #522268 8th Apr 2016 5:41pm
