![]() | Home > Technical > Clutch - MERDE!!!! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
sorry - spotted you'd replace the slave but missed the master cylinder.
No, as long as he knows what to check and has the correct parts the basics are the same. With a decent selection of tools [including a clutch alignment tool] and some common sense a willing and competent novice should be able to tackle the job. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Thanks new and improved HOG
![]() Just out of interest, how vital is the clutch alignment tool? He did use a tool, although seemed to be a creation rather than purpose built. Can this lead to the woes I have described above? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Have checked, apart from the Spigot, all is as you gave listed and what's more (bar the clutch being AP but coming from Ashcroft) all are OE. As mentioned with HOG above, I have not done the spigot. However, I'm still unclear if there is a difference between the 2.2 and 2.4 friction plate and cover or if they're one and the same? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
What he says ^^^
![]() I've done them by eye in the past too, and using lengths of dowel wrapped in tape as well as the usual using an old input shaft. If the shaft goes through the plate easily then the alignment will be ok. General clutch alignment tools with a variety of adapters for different plate and spigot bearing sizes can be got quite cheaply and give you a sense of security knowing you can tackle a variety of vehicles should the need arise Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Grenadier, I cannot believe the hassle you're having with a clutch. My sympathy! Lots of good knowledge and experience coming to your rescue, here. D2net
![]() Silly question - have you made any other changes like rubber mats or soundproofing in the footwell? The standard Defender rubber mat already touches the fully depressed clutch pedal. Cruise control - clutch pedal switch? Unlikely as you are planning to swap your vehicle soon, but thought I'd ask. 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
I admit to not having read the complete saga but if you changed the master cylinder have you checked that the pushrod setting is correct so that you are getting the appropriate amount of travel? Steve.
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
You got the problem sorted yet mate?
Nope. The mech gave our local indie a buzz and he thinks, assuming the mech is telling him the truth and what's actually going on, that the friction plate is the wrong one. Too thin. Not sure if that's possible? Anyone know if there are any differences between a 2.2, 2.4, perhaps tdi, that would allow the plate to be too thin yet still be fitted? Anyway, it's going to be dragged down the hill and opened up for a third time.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Well good luck with that.
If the friction plate is too thin then surely it would be less likely to drag rather than more likely? |
These images are from a copy of Microcat kindly hosted by a forum user.
It shows a difference in clutch mounting bolt depth for 2012-> also the WSM manual says they must be replaced along with clutch. Cant think how it would create your problems, but a perhaps something else to investigate? ![]() Click image to enlarge ![]() Click image to enlarge Edited to fix a pic. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by Cetane on 8th Apr 2016 10:36am. Edited 1 time in total |
Thanks Cetane. Anything will help. An ever increasing part of me thinks it's just the mech I have used is a bit useless....Hope the chap down the hill, the porfessed Defender nut I have posted about previously, will spot the problem and get is resolved sharpish. If not, strip and reassemble....
Believe in Sallanches there are three Land Rover specialists. One of them regularly gets mentioned in the french Land Mag magazine. Might be worth to check around about this.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Merci Eric,
Used to be three, the 'dealer' has changed to 'Subaru'. However the guy who provided the advice mentioned above is the one you're thinking of, AccroLand. You can see his passion in my thread 'Defender Love'. Nice guy. Only reason I didn't go to him in the first place is that he was booked until end of April and the Defender was supposed to be sold a week ago. Fortunately that has been delayed at least until May. By the way Eric, did you get your poster? If not, I have a copy (unopened) if you want one or an extra one, given you are actually on the collage. PM an address if you're interested and I'll pop it in the post. ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
