Home > Technical > Heater inlet plug/drain - how useful?
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Following condensation problems when the heater blower was used, plus rusty water ingress into the passenger footwell from the heater vent and the discovery of a small amount of rusty water sitting in the heater inlet because the rubber plug/drain was blocked with silt, I have removed it and can't see any point in putting it back (unless I plan to do some serious wading - which I don't).
Any comments?
Rob
Post #522156 8th Apr 2016 11:09am
Bps
D1 or d2 air con or not? My d2 air con drain tubes which run down either side of the gearbox were blocked leading to water filling up and coming out of the foot well vents when going round a corner. I cleaned them and took the little bit of rubber on the end off and not had any problems since
Post #522161 8th Apr 2016 11:23am
Bps
Sorry just realised not a discovery Banging Head
Post #522162 8th Apr 2016 11:24am
Bps
My 90 doesn't have the bung fitted as when i cleaned it it popped out rolled out the engine bay and down the drain. I never put it back and haven't had any problems as I don't do deep water either but I have a snow cowl fitted that keeps a lot of leaves and debris out
Post #522163 8th Apr 2016 11:27am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
mine is out with no negative effects.
I turn the fan off when wading as I've had it over the bonnet anyway by which point it's swamped anyway! It probably drains faster afterwards! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #522176 8th Apr 2016 11:59am
I'd try and get to the root cause of the water ingress, maybe fit a cowl on the intake and run the heater regularly to avoid any condensation rusting things from the inside out.
Post #522187 8th Apr 2016 12:24pm
Bps
Not wanting to hi jack the thread but I have a metal snow cowl for sale if you need one. Check out the for sale adds
Post #522188 8th Apr 2016 12:25pm
Mo Murphy
The first thing you should with a utility Land Rover is remove the fanny valve and throw it away. I've had no detrimental effects over the last 22 years and no damp air (apart from the time water bubbled out of the windscreen heater vents after particularly deep windscreen high wading 😀 ).
50 Shades of Pennine Grey
Post #522323 8th Apr 2016 8:44pm
90 Dreamer
just been searching and this thread pops up about removing the "fanny valve"
where exactly is it and does this help with interior steaming in heavy rain??
Post #802692 18th Nov 2019 1:37pm
Mo Murphy
You've been searching for ''fanny'' Dreamer ?
Post #802697 18th Nov 2019 2:40pm
90 Dreamer
never one to miss a search for 'fanny'................. Rolling with laughter
albeit i can't be a "new man" as i have not as yet discovered the elusive fanny valve........
Post #802699 18th Nov 2019 2:57pm
landy andy
The reason you get steaming up in heavy rain may be due to water being inside the heater box. To allow this to drain is a drain beak, Winn is on the lower side of the heater duct that runs from under the wing grill, to the heater fan assembly. If you run your hand along the bottom of this duct, so above inner wing, you discover the mentioned item, then give it a squeeze or pull it off and see if water gushes out.
Post #802706 18th Nov 2019 4:11pm
landy andy
Part 6 on image
Post #802707 18th Nov 2019 4:18pm
donmacn
(Delete all this) I hadn't realised it was a general query and from a resurrected post. Now who feels like a fanny? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #802709 18th Nov 2019 5:39pm
There is more than one of those vales in the ducting or at least there is on the Puma.
There is 3x in total.
I keep mine in, but keep them clear.
If you take them out, yes you'll not get clogging or moisture but instead you'll be drawing in anything from the engine at a lot.
And in the summer, that'll include some warm air too. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #802711 18th Nov 2019 6:07pm
