![]() | Home > Puma (Tdci) > Chassis and underbody wash |
| andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617
I just get under mine and wash it no need for ramps
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
I just use a garden hose with a nozzle on it. To my mind a powerwasher would remove any corrosion protection on the chassis/outriggers. I do it regularly and the nether regions stay clean. 1982 88" 2.25 diesel
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
^^^^ Same as me, pressure washer will drive water inside the chassis too.
I taped over the holes with black tape. I didn't tape over the bottom drain holes. 1982 88" 2.25 diesel
Only ones I taped was one each side under the rear arch, large ones.
They were a massive dirt trap, all the little ones aren't so bad and allow air through to dry out. |
Yeah, the place where the cable trunking enters the chassis rail behind the rear wheel took some amount of tape!!I left some of the holes on the inner faces open to allow air into the chassis like you have done. It's amazing how much cleaner and drier the inner faces of the chassis rails stay compared to the outer faces. 1982 88" 2.25 diesel
A lot of it is water splashing, most dirt and wet is just behind front wheels, not so much mid way and around rear wheels.
Front chassis section stays clean mainly. I try and avoid wading loads of water if I can, especially going into it at speed. |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Google, truck wash/MOT,your area.Cost is about £30 for a truck.HGV's can fail an MOT if the underside is excessively dirty so it's normal to have them jet washed beforehand.
As others have done, I did mine on the drive using a combination of ramps, pressure washer AND hose pipe.Paying extra attention to the rear and the large holes where the loom exits. If you off road your truck you probably need to have quite a few sessions underneath as you'll miss nearly all the mud traps.Took me months to thoroughly clean mine,which was fine because I learn't where all the mud traps are and made sure they got an extra dose of paint/Dinitrol. And don't worry about water inside the chassis,you get dirty,gritty,salty water inside everytime it rains (@60mph a tyre will easily shift a gallon of water PER SECOND,compared to a typical diy pressure washer of 1.5 gallons PER MINUTE) which is the real killer,so needs to flushed out,it will quickly dry when it stops raining (also dirty paint takes longer to dry and the longer it stays wet the quicker the paint deteriorates). imho,regular cleaning the underside is the best way to keep corrosion away,only takes a quick,light going over when done regularly. Fake edit:Almost 2 years after I jet washed,primed,painted and Dinitrolled my underside I dropped the fuel tank on it to swap a leaky pipe,the area around the pump/pipes was still full of mud,as I said, it took me MONTHS to jet wash my truck and I still didn't get rid of it all,lol. Pov.spec,ftw. 2006, 110,TD5. |
I find the biggest mudtraps are on top of the front outriggers which sit below the driver's and passenger's feet. The mud lodges between the top of the outrigger and the body. Next big trap is the inside of the rear crossmember behind the rear wheels. I hose these out with a garden hose and an adjustable spay nozzle everytime I wash the vehicle. The space between the tank and crossmember is also hosed out but as I can't see in, it's hard to know just how much crud gets left in there.
I'd say for a vehicle not subjected to regular off roading a garden hose with a spraing nozzle should be sufficient. I've never had a vehicle turned down at the test owing to dirty nether regions and I live in a rural area where we get lots of mud on the roads.. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
| Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921
I made my own rear wheel arch liners for my 110 van, and at the front fitted some of Gwyn Lewis's liners, but with my own additions, to keep the mud off the front outriggers and out of the front bumper.
Gwyn Lewis's website is here: http://www.gwynlewis4x4.co.uk/product-category/mudshields/ There's some pictures of my rear arches at the bottom of this page (I can't find the photos of the front, but I'm sure they're on here somewhere): http://www.defender2.net/forum/topic32129.html I ended up removing the original rear mudflaps altogether as they caught the spray my liners threw up and swirled it around in front of them. I then added some short flexible mudflaps onto the bottom edges of the rear of the liners which have since kept the rear crossmember and chassis very clean. Obviously, my liners would be a liability off tarmac, but apart from the odd trip up a verge, the van never goes 'off road'. |
Interesting
| RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115
I recently spent many hours cleaning mine in preparation for Dinitrol. The number of places you can find caked mud is amazing. When you are certain you have found it all, look again - you will find more!
I have a basic Defender commercial (van) which is my dog carrier and it has no wiring loom running through the chassis. This allowed me to use the 2" diameter holes in the chassis rails (one behind the front wheel and one at the back) to feed a hosepipe into the chassis and flush it out with clean water. It took a long, long time for the water to run clean. I then left it to dry for about three weeks while I was away. One I had put Rust Convertor and Cavity Wax inside the chassis I used 2" grommets to block the large holes as they seem designed to let water and salt into the chassis, especially the front ones which are in direct line of the front wheels when turning. I used underbody wax over the outside of the chassis and under the bodywork, then finished off with a complete set of Gwyn Lewis mud shields/liners. |
If a job is worth doing ....etc etc
| srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
Hire or borrow a hot water pressure washer if you want to get it properly clean, then you can just get right under it, no need for a ramp or waterproofs as it's like lying in the bath
I point the nozzle everywhere it'll go - inside all the holes in the chassis, get all the crap out. Take it for a drive after, up and down a few steep hills to drain the water out. Then go round with a air-line/blow-gun and to blow the rest of the moisture out to properly get it all nice and dry (and remove a load more muck that you missed with the power washer!). |
