![]() | Home > Maintenance & Modifications > Hazard switch update |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
You can fit a Carling one, this is what I have fitted to my 1986 90.
Or did you want a genuine LR one off a later vehicle? ONE LIFE, GET IT! |
steventheplumber Member Since: 29 Apr 2014 Location: Lincolnshire Posts: 767 ![]() ![]() ![]() |
Yes was looking at one for a later vehicle.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Where do you want to fit it exactly, do you have somewhere in mind for it to go?
Have a mud centre console. I think it would be in better position in the centre .
OK so you need a switch that fits the Mud console, or a way of fitting a late Td5/Puma style into it.
Edit: Stiff1 has a hazard switch carrier for sale: http://www.defender2.net/forum/post521557.html#521557 ![]() ![]() |
Yes hopefully it can plug into the old hazard switch. It like the boomslang lighting cable
Unlikely to find a plug-and-play adapter loom, it's not a common thing to update the hazard switch.
You could have one made though I guess. ![]() ![]() |
Will look into having made up if possible/ price is OK. Would think it would be OK for not?
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 602 ![]() ![]() ![]() |
Unfortunately the two are not directly comparable.
I actually went sort of the other way, changed the original Puma hazard switch for one from a Disco 2 as it fits into the standard Puma switch holes. Got Paul Mc on here to make me up a relay, excellent work. I do have a Puma hazard switch and dedicated holder as Martin stated if you are interested. |
Yes am interested can you PM me want you are looking for it.
