Home > Technical > How-To: Side locker Nakatanenga
Page 1 of 3 123>
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
Before I end up with a useless big square whole in the side of Olli, has anyone already installed a side locker from Nakatanenga?
Or similar?
Part from the door, locker and some small plates and rivets, nothing else came with it. 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #521397 6th Apr 2016 6:46am
leeds
I have not fitted a side locker so can not give direct advice.
Please drop an email to info@nakatanenga.de I am sure someone there can help out.
Brendan
Post #521409 6th Apr 2016 8:19am
Penguin
I've contacted Nakatanenga. Their answer:
Nakatanenga wrote:
no there are no instructions, as all Defenders are individual. If in doubt, please ask a professional.
Post #521418 6th Apr 2016 9:24am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
I'm sure I've seen a vid on YouTube try there, good luck Thumbs Up Cogito ergo sum
Post #521422 6th Apr 2016 9:37am
simon67
England 2004 Defender 90 Td5 HT Rutland Red
Look for a professional on here, good luck with that one
Have a large group of happy amateurs who each have an opinion on everything Very Happy
I would ask the indies round you for a quote, at least you are covered if they Censored it up
Post #521423 6th Apr 2016 9:39am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
This seems a pretty poor reply for a company selling to the public. How does the professional know to install their equipment safely without product information or instructions? 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #521427 6th Apr 2016 9:50am
nakatanenga
Germany
To be honest: The job is pretty easy, but requires some skilful measurements. Depending on the MY and the built quality the measures are a bit different. So there is NO CHANCE for a template.
The instructions are as following:
measure the hole
cut the hole
rivet the thingy in
job done WANTED:
SII or SIII in max 1.5k
Post #521445 6th Apr 2016 10:39am
Penguin
thx, but, By just rivetting the box to the side pannel, I'm not convinced that can hold the load?
And what are the small perforated plates for and the long small, thin bar with ovals in?
Post #521451 6th Apr 2016 10:48am
How much did you pay for the kit?
Post #521471 6th Apr 2016 11:58am
Penguin
289,00 €
https://www.nakatanenga.de/zubehoer/ordnun...eschichtet
Cost to be installed by them € 375.00 (for an easy job, not bad....)
https://www.nakatanenga.de/zubehoer/ordnun...fender-110 28/02 - Loss of a good friend...
Post #521474 6th Apr 2016 12:09pm
Measure 8 times, cut once.
Post #521477 6th Apr 2016 12:16pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi Penguin,
From the picture on their website :
I would say that the lines of spot welds is your best reference.
But some pictures showing the underside / rearside after mounting would indeed be helpful.
Good luck on the install Thumbs Up Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #521485 6th Apr 2016 12:47pm
Penguin
hard to tell Peter.
As you maybe saw, the door I have is different from the models posted on their site.
And the door drops open now.
So if the size is different... I'm .... Very Happy
It'll be indeed measure x8, measure again, cut and, as usual followed, by a lot of swearing in different languages Very Happy 28/02 - Loss of a good friend...
Post #521486 6th Apr 2016 12:51pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Are the perforated plates spreader plates for the rivet to pass through behind the panel maybe ?? "Procrastination is the thief of time"
Post #521497 6th Apr 2016 1:41pm
nakatanenga
Germany
It will hold load up to 10kg, even under the harshest offroad conditions. Proofed.
The perforated plates can be used as additional support (over 10kg load)
What do you mean with: long small, thin bar with ovals in WANTED:
Post #521500 6th Apr 2016 2:06pm
Page 1 of 3 123>
