![]() | Home > Puma (Tdci) > Major coolant leak |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20979 ![]() ![]() |
Same as mine was, get underneat and have a look from underneath with a light.
Wear eye protection in case a stray drip comes down. I have the torque for the bolts if required but you will need to drain and bleed the system to remove it as well as remove the Acc drive belt and brake vac pump |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 ![]() ![]() ![]() |
What was it on yours that was leaking?
I thought it was power steering fluid on mine at first but the heaters stopped working within a couple of miles so it's definitely coolant, I just can't see where it's coming from |
Well I've had loads or tribulations with mine. I'll drop you a 'PM'.
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
If it's losing it that quickly I would say it may be a pipe thats your problem? There are a few on the n/s of engine. The egr has a couple of pipes to/from it. Just a thought.
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Same problem few month again.
Check the hoses. One of mine rubbed against a chassis support and finally made a hole. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
I'll get under it tomorrow and have a proper look, where abouts is the egr located? Or will it be quite obvious. I'm not so familiar with these engines, yet!
Thanks |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Mine lost a load of coolant when the red engine lift bracket at the back of the engine wore thru the hose..
The bracket is meant to be taken off by the dealer at the pre delivery check.. Worth having a quick lookie lookie to see if it's still in place.. Then the dealer can pay for the fix! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
