Home > Technical > Diff gear position
jangtm76
France 2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Diff gear position
Hi, All!
Just got my Landy yesterday and I'm enjoying every min.with it.
Quick question. I see orange light on the speedometer. Is this normal?
Post #521097 5th Apr 2016 11:32am
Roy5695
that means the difflock is engaged, some might say to read the manual as driving around with it engaged will cause serious damage if driving on tarmac, move the little gearstick to the right!
Post #521100 5th Apr 2016 11:45am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
If you have driven like that you may well of caused some wind-up, apply the t-brake and jack up a front wheel, as the tyre looses traction it shall spin slightly (note it will only spin if there is sufficient wind-up, normal use the wheel should remain still). 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #521104 5th Apr 2016 12:00pm
ericvv
Probably no need to jack up a wheel to undo eventual wind-up. Was all very well explained by Glyn in his below. Thumbs Up
Eric
Glynparry25 wrote:
The Diff lock works off a spring on or off possition. When you select diff lock it nputs pressure on the spring- when the gears line up the collar slides across and locks them together (this then pushes the switch which puts the light on your dash.
When you dissengage the diff lock it does the opposite. it pulls the spring away and that then allows the collar to slide back which releases the two gears.... and the light goes off.
If you have 'wind up' where the two gears in the collar are tightly jammed in opposite directions it will not let the collart slide off and even though your transfer leaver is across the light is still on. This is when you reverse back and turn the steering from lock to lock (or jack up one wheel) as it releives the stress and the collar then is free to slide, and the light goes off.
The diff lock can't be half on.... well it could but only in extreme circumstances and it would be a one in a million chance.
So..... if the light is off, and you don't feel wind up (steering feels forced) then the diff lock is off and there will be no problems.
Glyn Dog Sheep
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #521115 5th Apr 2016 12:46pm
jangtm76
Oh, shoot! I've been driving like that all day long up to 100km yesterday.
Hope I didn't break anything. :/
Thanks for the info.
Post #521210 5th Apr 2016 5:35pm
jangtm76
Eric
Glyn Dog Sheep
So, I should drive under normal condition with the light off I guess?
Post #521212 5th Apr 2016 5:37pm
jangtm76
In English, please? Smile
I don't have any knowledge on Defender's four wheel system. Sad
Did I make a terrible mistake drivng like this? How do I solve the problem?
Thanks!
Post #521217 5th Apr 2016 5:47pm
dorsetsmith
So, I should drive under normal condition with the light off (YES)
Diff lock , it locks front and rear drive together
Post #521219 5th Apr 2016 5:55pm
Happyoldgit
When that yellow light is lit there is a positive connection between the front and rear axles. For normal road use the light should be unlit / off / not showing.
Did the vehicle come with its handbook - if so may I respectfully suggest that you read it soon. Steve.
http://forums.lr4x4.com
Post #521226 5th Apr 2016 6:20pm
jangtm76
My dealer didn't give me the manual Sad
Post #521228 5th Apr 2016 6:22pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
jangtm76,
Welcome to the joys of landrover ownership and to the forum!
As the others have said , the light on the speedo should not be on for 'normal' onroad driving, so you should move the short lever to the right and into its normal position.
If the light does not go off, then slowly drive in reverse and move the steering wheel from full left to full right and it should go out.
As you are new to Defenders and landrover in general, may I suggest that you have a chat to your local landrover dealer and see if there are any offroad courses in the area that have the ability to show you what a remarkable vehicle you have bought.. in the UK we have landrover experience and they are able to take you through basic off road driving techniques and show you the limitations of your vehicle, how to use the various gears and give you confidence in how to use the defender in anger...
maybe see if any of our French members are nearby to meet up with you and go over the finer points - with a glass of wine or two..
just a thought Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #521229 5th Apr 2016 6:28pm
Cupboard
So now we've learnt when the diff-lock should be off, now when it should be on:
Basically any time you're not a sealed road.
Post #521234 5th Apr 2016 6:42pm
dorsetsmith
NO owners hand book or service portfolio Question on 2015 110 land rover Exclamation
Post #521255 5th Apr 2016 7:17pm
Doubledoom
United Kingdom 2016 Defender 90 Puma 2.2 SW Santorini Black
I didnt get one on mine to begin with. I had to ask for it. Even then I only got the manual as the service history is electronic now.
Post #521367 5th Apr 2016 11:06pm
jangtm76
Found it Sad
Post #521369 5th Apr 2016 11:15pm
