![]() | Home > Technical > ABS/TC |
| Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670
Yeh i know what you mean but this was with a TD5 in 98-00ish. Nothing to do with that idiot that cant drive. Was something to do with needing to stop half way down a hill and the ABS would release the brakes rather than locking up and stopping you. Think somebody in this country ended up in a ditch at the bottom of a hill because of it and caused a stink about it. Cant remember the exact details and what he was trying to do at the time, will see if i can find out more. Pete. |
| Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113
I was testing ABS on my weekend racer and defender a year ago : performing some tests stoping on tarmac, grass , mud... and im sure abs wil cause longer stopping distanceīs in general except dry... Off course after reading a lot about abs in racing and in general , I ditched it from my weekend racer (old 520i) I will try to explain what I found : sorry for the bad grammar and please feel free to correct me, thatīs why there are discussion boards . Letīs say you are driving on grass at a reasonable speed : and suddenly brake as hard as you can , the abs wile intervene and will not lockup any wheels : it simply doesn't allow the pedal to go any further ! I tried several times to put almost my whole weight on the pedal, it wouldn't move an inch more! Now you say ; thatīs normal thatīs abs , you can steer then ... But! if your tire while cruising is using letīs say 5% of itīs potential grip and if you brake you will use 95%-100% of the tireīs grip between abs impulses to brake... Then you will have a remaining 5%-0% for steering ... and also count the laws of physics into that (a moving object always travels straight) and also weight transfer is an important variable (inside wheels lock faster) Now most newer cars with their ESP are much... much... more aware about some factors : they have Gyroscopeīs ,accelerometers,clutch sensor,even a gear sensor nowadays (shift display) and also have a steering wheel position sensor . those new cars can adjust their braking really accurately ,based on the inputs of the steering wheel sensor , wheel sensors, and brake,clutch and accelerator pedal. this combined with the gyroscope , and accelerometers: The ECU knowīs which direction the car is moving . and if the direction doesn't match the steering wheel senor : the car will try to brake individual wheels and steer the vehicle : example: If you brake really hard and steer : the ESP ECU knows you want to go that way and brake. it will try to figure out the needed grip to steer lets say 30% , and the left over grip to brake 70% now we all now that a defender does not have all those gizmoīs and thank god who knows what will hapen! A defenderīs abs is Analogue ... it always wants to stop as quickly as possible and it tryīs to do that realy hard . It works in dry in a straight line : and u can maneuver a bit but in the wet... please . thereīs almost no steering... now the biggest drawback for me with almost all ABS systems is : if you are braking hard ... and 1 wheel hits a sheet of ice or mud even those white roadmarkings ,track curbs and the other 3 wheels have 100% grip. The abs will push up your pedal and make sure the car is going to go straight and does not deviate . because of 1 wheel having less grip also the rear left will most likely hit the patch! And like I earlier said the ABS pushes the pedal back... ! So when you got full grip again , it takes some time the push the pedal back down... (maybe 0,1sec delay) basic mathīs: So there u have 1000N of stopping grip per on the front wheels 500N on the backwheels 3000max total on perfect dry conditions with non locking wheels Lets say the left front hits a slippery patch(with 50% grip) and decreases to : 500N right front also goes to 500N to keep the car straight 2x = 1000N and the two rears go to 250 each (logic) x2 =500N this is aproxx 1500N letīs sum it up : 3000N = with no abs intervention ABS you have 1500N and you drive straight but you have an intervention of +-0,5 seconds and letīs say the driver feathers the brake try to not lock the wheels (and feels when they lock) non ABS you have 2100N and possible risk of oversteer . thatīs +-600N extra 28% stopping power now you can do the math for a stop from 25m/s 90km/h dry road, perfect grip, no locking : 55m dry road, perfect grip, no locking +1sec l : 80m dry road, perfect grip, good driver so you lose +-15% : +1sec : 92m Abs dry road, perfect grip : 5% loss of grip abs locking pulse (you wont notice the loss) +1sec : 84m patch 1,0sec 78% no abs good and a good driver : = 85,55m patch 1,1sec 50% with abs +1sec : = 93.5m these calculations are probably not perfect... if I made a mistake feel free to correct , I am not studying math so if my basic mathīs are correct : even if thereīs no black ice or ice , ABS can cause longer braking distanceīs And about ABS on ice : Ice has at leas some friction : if you lock your wheels wouldnīt that create more friction and heat , so the can cut in the ice? or is the friction too low? greetz ! Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
First time I have heared of anything like that. Sounds like something faulty..... otherwise it would have ended up in a recall.
*Edit*.... when the wheels would have started turning when the abs released it the sensors on the hub would have detected movement again and re-applied the brakes. Talking about recalls...... did you know that 2 years ago it was recognised that the large glass on the roof on the Ford Galaxy was prone to comming free and there were incidents of it either coming off whilst driving at speed or falling into the vehicle..... they kept that one quiet. Glyn |
Not saying it right, just what ive read. Most likely driver error but trying to blame land rover. Pete. |
Yeah, the whole.... I did everything right but the vehicle just crashed into the hedge that jamp out in front of me Glyn |
Alexke,
Yes and no. What you have to remember is that when a tyre locks up you aren't getting the potential out of it therefore less friction, so look at it this way: A. You are braking to hard already if have locked up/ ABS is kicking in (Bad driving) B. We will say on a scale from 1-10 the friction of a tyre 1 being none, 10 being loads of friction. A tyre that is locked/ skidding will have a friction of say 3 where normally it will be 7. So a locked up tyre will take longer to stop than one that has contact? ABS isn't 100%.0%.100%.0%..... it works its way up and down so friction will be more of a staged 7.5.3.5.7.5.3.5. which means it will have an average of say 5. I have tried to keep it simple (my brain is hurting today). As for Ice, yes you have a valid point.... but only if it is just single wheels rather than complete ice. Not so much for water as the whole surface is normally wet. Glyn |
like i mentioned itīs
I find this fascinating :if a wheel locks up on a wet road : the friction of rubbing a locked tire = massive heat road underneath tire heats up and giveīs more grip. And the friction heat will make the rubber more sticky and then shortining stopping distance but the boiling of HēO underneath the tire can build up and expand , therefore reducing friction just some food for tought! F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
To be honest I don't think the Heating up/ cooling down would make enough of a difference unless you were doing considerable speed... also remember that the tyre is heating up but the road, and the rain is cooling.. All depends on tyre compounds etc.. Cheap tyre will not produce much heat as the rubber is so hard and it will 'slide' along the surface where if you had a set of Yokohama or Toyo R888 then you will have loads of friction/ heat and the need to go back to the tyre shop to buy a new set. Basic moral of the story is to think about the way you drive..... ABS ISN'T a form of breaking and more of a safety feature that kicks in to help you out when all else has gone to Sh!t. Just a quick reminder to all the folks out there who have done the UK driving test.... what is the first thing you are supposed to do if you lock the brakes on a car (dunno if they teach the same in other countries)? A- push the pedal through the floor and close your eyes and pray. B- release the brake and re-apply a force so that the vehicle doesn't skid. What is the rule with driving tests now... when I did it you had to do the good old emergency stop where you had to come to a controlled stop as short as possible without skidding or if you did skid you had to do the off and on tecnique as above....... what if the car has ABS... as the testee could just jump on the brakes and let the ABS control it (or is ABS not considered as under control?). Glyn |
| KarlB Member Since: 08 Feb 2010 Location: Canberra Posts: 91
Seth Afrikan I believe, not an Aussie. Cheers KarlB |
Yes you are right. I stand corrected. I keep thinking Aussie because my Bro is as good as one now and looks like I will be looking down that route in the near future. Glyn |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
First of all lets remember what ABS is and does.
ABS is a driver aid that maintains the maximum controllable traction to the wheels to enable proper vehicle control. Land Rover have been putting ABS in cars long before any manufacture - you will recall its in the Range Rover Classic - they spent a lot of money working out a system that wouldnt screw up off road...some manufactures still have sussed that (properly). There are some occasions in some setups where you will, by skidding, probably stop shorter than an abs car...but ignoring you are out of control, you wont be able to control the car in the majority of situations, ABS will ensure you retain control and stop in the fastest time possible. Mike |
| Arctic Member Since: 25 Aug 2010 Location: Europe Posts: 45 |
The shortest stopping distance should be obtained from the tires at the point just prior to wheel lock-up. Therefore, locking the wheels is not a good idea. In snow it sometimes helps to let it build up in front of the tires when braking.
On a slightly different note, how reliable is the ABS/TC system? Have any/many of you had any issues with the sensors etc? |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406
works on Wabco system but not the Bosch system Cheers
itīs true.. less drama with ABS in the end ,: but it wont save you i had 1 senor replaced... i am gonna try to push my pedal 10 times tomorrow : but do i have to do this in short pulses or long pulses? grtz Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
