Home > Td5 > Whats this noise
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
Whats this noise
I have a squeaky, possibly hissing??, noise from the engine - perhaps a bit like when the alternator went on the Marcos. But
I cant track it down with my stethoscope things - does it sound familiar?
CC
Post #520887 4th Apr 2016 3:33pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Sounds like something is loose, I'd say check pulley bolts etc to ensure they are right, is the tensioner moving a lot? 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #520888 4th Apr 2016 3:44pm
dorsetsmith
Sounds change if AC is on or off Question
Post #520894 4th Apr 2016 4:04pm
chopcat
ah ha
the ac has recently dumped the gas so possibly the pump is having a bit of trouble.
is there any problem in running it without it gassed?
CC
Post #520895 4th Apr 2016 4:06pm
Mash
The AC pump should be a free spool clutch until in is turned on, if the clutch has stuck on this would be a reason for the noise. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #520898 4th Apr 2016 4:15pm
rallysteve
Sounds like a bearing on one of the things on the aux belt to me. Could be the idler or tensioner or worse could be a/c compressor or PAS pump.
Worth whipping the belt off and having a feel of the pulleys for endfloat or rough rotations.
Post #520899 4th Apr 2016 4:15pm
dorsetsmith
AC compressor will probable sound nose if you have AC system leak, AC compressor has elect magnetic clutch so with AC switch off compressor free wheel only
Post #520900 4th Apr 2016 4:20pm
Lionel
Australia
Re: Whats this noise
chopcat wrote:
https://www.youtube.com/watch?v=cSoAl_m8TCY
CC
Could be right out of left field, but leaking exhaust manifold gaskets (quite common on TD5s) can make some very weird noises.
Worth a look.
Cheers,
Lionel
Post #521125 5th Apr 2016 12:18pm
Lionel
Australia
Did you find out what the noise was?
Cheers,
Lionel
Post #524088 15th Apr 2016 2:17am
chopcat
I was taking the D4 for a service so booked the TD5 in as well.
As soon as I told it I was taking it toi see Steve at James French it stopped making the noise. So we didnt go for a diagnosis.
At the moment I am waiting for it to re appear to look at it further.
CC
Post #524092 15th Apr 2016 6:10am
chopcat
Its this pulley
Seemed fine and then suddenly seized. Hence i am waiting for a recovery truck.
The pulley to the rhs underneath the power steering pump. Or is it the air con pump?
Anyone an idea of the part number and where best to get one.
CC
Post #524740 17th Apr 2016 1:53pm
dorsetsmith
yellow is PSP QVB101350 red is one there's http://www.allbrit.de/UNI.cfm?PAGE=751115&SPRACHE=EN
Post #524746 17th Apr 2016 2:25pm
chopcat
Itsa da red one.
I think (from my googling waiting for the lady recovery driver) that its called the idler pulley
Amazingly it is totally solid.
CC
Post #524752 17th Apr 2016 2:35pm
chopcat
Here we go...the go anywhere vehicle
Post #524822 17th Apr 2016 6:56pm
chopcat
This is what it was....
Post #525343 19th Apr 2016 5:22pm
