Home > Maintenance & Modifications > Seat Risers again
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
Seat Risers again
Having fitted seat risers and a 14 Momo wheel i can now stretch out with aplomb. But.......Im too high and get an ache in the thigh on long journey. They are Mudstuff riser the box section type. Is there a way to get the rail extention without the height. I only need around 30mm rearward movement 2004 110 CSW (Called Yoda)
Post #519715 31st Mar 2016 7:34pm
Stiff1
In being so undecided on which risers to get, I went with the spacers under the rear seat bolts suggestion and have been so happy with it I'm not going to bother with dedicated risers at all.
Post #519738 31st Mar 2016 8:03pm
leeds
Have a look at these
Brendan
Post #519794 31st Mar 2016 9:37pm
nitram17
Re: Seat Risers again
As far as i am aware you there is a minimum height(approx 30mm) you have to raise the back of the seat runners to get past the lip that is present running across the truck floor stopping the seat from moving backwards ..You can use washers to overcome this or buy seat raisers..the box section raisers also raise the seat at the front..but the ones sold by Brenden which to me look like copies of the Australian Mulgo seat raisers are the best compromise IMHO you raise your hips at the back but only raise the knees at the front a little which gives you a better sitting angle /position with less stress on the muscles of the back( the pain in your thigh might be referred from your back).I am unsure what is the purpose of the metal lip on the floor of the truck behind the seats ,i assume its for strength but if its not(somebody on here will know)i wonder if you could cut or grind the lip down to allow the seats to slide back without raising the seat.
Post #519811 31st Mar 2016 10:13pm
Simali
That was my thought take grinder to it and cut two slots 2004 110 CSW (Called Yoda)
Post #519822 31st Mar 2016 11:02pm
chris01743
United Kingdom 2010 Defender 90 Puma 2.4 HT Tamar Blue
Hi all,
I fitted a britpart bulkhead reduction kit tried seat raiser no good to high so I cut two slot in the lip re positioned seat rail back 1 1/2 inches now perfect driving position for me at 6 foot I will try to send photo later
Chris
Post #521167 5th Apr 2016 2:37pm
Simali
Chris
a pic would be great 2004 110 CSW (Called Yoda)
Post #521178 5th Apr 2016 2:54pm
chris01743
Will attempt picture tomorrow
Post #521268 5th Apr 2016 6:52pm
chris01743
try this
Post #522195 8th Apr 2016 11:33am
chris01743
[img]https://www.defender2.net/gallery/albums/userpics/19560/normal_20160407_105618.jpg[/img]
[img]https://www.defender2.net/gallery/albums/userpics/19560/normal_20160407_105501.jpg[/img]
try this
Post #522201 8th Apr 2016 11:37am
