Home > Technical > ABS/TC
Page 1 of 3 123>
Arctic
ABS/TC
Ok, looking into buying a new Defender Hard Top and was wondering if it would be worth getting the ABS/TC option fitted or not? Any thoughts? Would be left hand drive for Europe so the option is around 1200 euros I think.
Would prob. fit an ARB diff. lock in the rear later anyway so traction control doesn't seem to be so essential. ABS I have mixed feelings about. Could be useful but then again not essential, especially as, where I am, I have noticed that (in cars) it often struggles anyway (snow, ice etc).
Thoughts would be appreciated!
Post #51890 8th Jan 2011 11:28pm
ABS/TC - on a wet slippery road, ABS could save you €1200 avoiding a tree/wall/another car .. none of us are perfect drivers - personally I'd go for it.
Whereabouts in Europe are you ?
Post #51915 9th Jan 2011 8:36am
jst
if you are in the cold and snow alot (80% of mileage) and on std rubber ie non studded i wouldnt bother. sometimes its better to have the snow pile up in front of a sliding wheel to aid your stopping. but with no ABS you wouldnt have steering.
if you run studded tyres then i would have it yes.
If you are fitting a rear locker then have a look at the other TC/locker debates/threads on here. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #51928 9th Jan 2011 10:16am
Alexke
Belgium
my experience :
1st ! just drive defensively!
2nd : I got General Grabbers
they are known for bad grip(rain) and good miles/value
3.) itīs very true that ABS on the defender and in general : prolongs the stopping distance.
itīs been 2 times already that I just turned off the engine in an emergency to lock them up.
One time i pulled the Handbrake to lock the wheels , got it into skid locking 4 wheels and sliding Sideways .
this was on a T Juction at 30km/h on black ice : ABS just intervened but and the truck would not stop.
After the T section was a 1.2m deep canal .
when I pulled the handbrake , the truck rotated 90° : so i was going side ways . at the canal.
just before the canal , my 2 side wheels plowed in the (luckily) unfrozen ground : Stopping the truck , mere inches away... I almost soiled myself !
If i didnt pulled the handbrake , I would have definitely drove into there with my abs.
4th) my experience on dry roads is good, especially at higher speeds .
5th) TC are electronic lockers and stop spinning wheels
it really helps off road ! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #51950 9th Jan 2011 12:20pm
Glynparry25
The way I look at it is pro's and con's. If I were to buy again I would opt for them. The ABS has saved me more times than hindered me and same wirth the TC... I have only not liked it on one occasion, the rest of the time it has kicked in it has been helpfull.
If it is black Ice it wouldn't make a difference if you had ABS or not. One of my previous cars didn't have ABS and whilst turning around a corner I noticed a car with it's brake lights on with the only junction near me (200m up the road). I locked up and slid the 200m and only missed the other car because I managed to get one wheel on the verge where there was a little grip.
Glyn Sheep
Post #52002 9th Jan 2011 6:26pm
mse
I would rather have ABS and TC than not have it - better more times than it isnt as said by Glyn Mike
Post #52006 9th Jan 2011 6:31pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
And if you dont want to use it for some reason then you only have to press the pedal 10 times before cranking the engine and it goes off, if you dont have it fitted you cant turn it on!
Pete.
Post #52009 9th Jan 2011 6:44pm
mse
Pete.
Not tried that - but yes if it works Mike
Post #52013 9th Jan 2011 7:04pm
Zinke
Works up to 2010MY for sure, think they have changed from wabco to bosch (think its bosch?) for the 2011MY so not had chance to try it out yet on the newer system.
Pete.
Post #52015 9th Jan 2011 7:10pm
mse
Pete.
You are right Wabco to Bosch at July 2010 for the 2011MY...i have the Wabco; but still not tried it yet (but never had a need) Mike
Post #52017 9th Jan 2011 7:15pm
jerseyman
Alexke wrote:
my experience :
Really? On snow perhaps. but I would like to see definitive (not anecdotal) evidence of any other situation where ABS prolongs stopping distance.
Brian
Post #52031 9th Jan 2011 7:44pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
on snow its a pain in the a**e Twisted Evil
Post #52035 9th Jan 2011 7:50pm
mse
Only if your going to quickly and need to stop more quickly Mike
Post #52036 9th Jan 2011 7:52pm
Zinke
I seem to remember something about going down very steep muddy hills that it can cause some problems too with the ABS. Think LRO picked up on it when the Defender first got ABS/TC.
Pete.
Post #52038 9th Jan 2011 7:54pm
Glynparry25
Need more practice.... you shouldn't need to yse your brakes in the snow, all about slow accelerating and very sloooooooooooooooooooooooooooooow engine braking with maybe the slightest brake pedal to slow and use brakes to do the final stop.
Glyn
Post #52055 9th Jan 2011 8:58pm
Page 1 of 3 123>
